Old 12-26-2016, 08:54 PM   #1
'63MurderTruck
'63MurderTruck's Avatar
'63 C10 Upper Ball Joint Bolt TOO SHORT
I'm putting 2.5" drop spindles on my sons '63 C10...
The upper frame on new spindles are approx 1/4" thicker than the originals. So, it's impossible to get the castle bolt even close to being able to get the cotter pin in.
Does anyone know of any aftermarket UPPER BALL JOINTS with a longer bolt?
If not, can anyone think of any other ways to solve this problem?
Been doing some 'googling'...
Will this work? They're 1/2" inch longer than originals...
https://www.amazon.com/Proforged-101.../dp/B008VQKP5A
Or these, which are 1" longer
https://www.summitracing.com/parts/q...del/c10-pickup
My concern with these longer ball joint bolts is that the diameter of the hole will not allow the aftermarket spindle to travel any further up the shaft than they already are on the originals. Does that make sense?
'63MurderTruck is offline   Reply With Quote
Old 12-26-2016, 09:19 PM   #2
PGSigns
PGSigns's Avatar
Re: '63 C10 Upper Ball Joint Bolt TOO SHORT
What year group spindles did you order? Can you post pics of the stuff you pulled off and the control arms? There are a couple of different ball joints used over the years.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-26-2016, 09:24 PM   #3
'63MurderTruck
I ordered the brakes and spindles off ebay. They were supposed to be made for this year truck, a 1963 C10.
I'll take some pix tomorrow.
Jimmy
Old 12-26-2016, 09:47 PM   #4
'63MurderTruck
I ordered these ball joints...
I'll update this after they arrive and check to see if they work.
Old 12-26-2016, 09:55 PM   #5
PGSigns
PGSigns's Avatar
Its the size of the taper that is important and not the length of the threads. Is this a drum brake truck or did it have a disc swap on it?
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 12-27-2016, 03:26 AM   #6
'63MurderTruck
It has drums, currently switching over to disc brakes with 2.5" drop spindles.
The main issue is that the thickness of the spindle frame where the top ball joint goes through is 1/4-1/2" THICKER than the original spindle.
Jimmy
Old 12-27-2016, 04:54 PM   #7
Grounded63
Somewhat of a similar issue, I installed a lowering kit from western chassis. The new supplied castle nuts were taller than a factory style. Where the " Crown " section was built on top of the nut, and not into the nut. If that makes sense, maybe something to look at.
Grounded63 is offline   Reply With Quote
