12-27-2016, 03:47 PM | #1 |
Junior Member
Brake Conversion Parts
I have disc brakes on the front and am converting to disc brakes in the rear. 1969 K5 Blazer, 10 bolt front, 14 bolt rear. Going to install a master cylinder from 1977 Corvette with dual reservoirs. Since I will have all disc brakes do I still need the proportioning valve with both front and rear feeds from the master cylinder? Or do I do away with the stock proportioning valve and install an adjustable proportioning valve in the rear line only? I guess it could be one or the other? Thanks in advance.
1964 Chevy Suburban 4x4 1966 GMC Suburban 4x4 |
12-27-2016, 04:32 PM | #2 |
Re: Brake Conversion Parts
Stock proportioning valve has to go.. You would need a valve for the rear..
12-27-2016, 07:53 PM | #3 |
Junior Member
Thank you very much.
