Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
LS OEM Accessory Drive Questions
I am under the impression that GM makes 3 different offset accessory drive set-ups for the LS engine.
A short set-up (close to the engine) for Corvette/Cadillac CTS-V, a mid set-up if you will (3/4" increased distance from engine) for F-Body & GTO, and a long Set-up (1.5" increased distance from engine) for the trucks. My questions are: Which offset set-up does the Caprice use? Which offset set-up does the Trailblazer SS use? I am trying to determine if the Caprice or GTO uses the same accessory drive set-up as the Trailblazer SS, as they both have a A/C bracket that incorporates both an idler pulley and a tensioner pulley, where the TBSS only has a tensioner pulley. I constantly throw the A/C belt on my TBSS during hard 1-2 shifts, and have read that this is why GM added the idler pulley to the newer A/C brackets. the GM part No. to the newer improved bracket for the Caprice that I am referring to is #92252927. I have no idea what the bracket part# for the GTO is... Any insight on this issue would be greatly appreciated!
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=512904 |
#2 | |
![]() Join Date: Jul 2009
Re: LS OEM Accessory Drive Questions
#3 | |
It seems as though I will need to try to find an alternative cure to my A/C belt throwing problems. Any ideas are welcome!
#4 | |
http://www.tickperformance.com/katec...elt-tensioner/
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
#5 | |
The tensioner that you showed is for the main serpentine belt...not much help with this. After the 1st time that this happened, I replaced the tensioner for the secondary belt thinking that this would cure my problems, but it didn't. Now I have read that the spring force in the aftermarket tensioners isn't great enough....So, I don't know what to believe. I do know that I just put a new motor in this vehicle with very good cam & top of the line valve train, then broke-in the motor properly for 5000 mi. added A CAI, & LS7 MAF, and had it tuned, but I cant even get on it good without throwing the A/C belt... If I back out of it for the 1-2 shift all is good, but how much fun is that?
#6 | |
I get the feeling this is a new problem, since the new engine was installed? The TBSS engine uses the same compressor bracket as the trucks do and I have never heard of anyone having problems throwing that belt, so to me it almost sounds like something is misaligned. I would double check that everything is straight and tight. Does the crank pulley wobble any at all?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
