01-03-2017, 08:11 PM | #1 |
Headlight problems
I have a 72 burb,I have replaced my dimmer switch and I have high beams at the light but no low beams, I have voltage coming from the low beam side of my dimmer switch but nothing at the light, has anyone else run across this issue .Thanks Kevin
01-04-2017, 01:09 AM | #2 |
Post Whore
Re: Headlight problems
Check for voltage at the headlight. It will be either the light green or the tan wire. (Tan I think for low beams) If no voltage then check the same colors at the firewall connector. You may have to unbolt the connector to access the pins. If you have voltage at the headlight test the bulbs with an ohm meter.
Good luck.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
