Old 01-10-2017, 01:20 PM   #1
nacho55
2013 5.3 swap in a 2008 Yukon now high idle issues
So this weekend I helped my buddie swap out a high mileage 5.3 from his 2008 Yukon with a 5.3 from a 2013, everything looked identical and plugged in the same except the new motor had an additional sensor below the water pump in the middle of the timing cover near the sensor below the water pump to the left if facing the motor. Well it starts and idles a little high in park around 1100-1200 but soon as you give it any gas it revs up and then revs up to 4-5000 and just stays until you turn the key back off.. We tried both throttle bodies and everything seems to be hooked up fine and no leaks but not sure on this. Sorry for the long winded question
Any ideas would be appreciated
nacho55 is offline   Reply With Quote
Old 01-10-2017, 11:27 PM   #2
truckdude239
truckdude239's Avatar
Re: 2013 5.3 swap in a 2008 Yukon now high idle issues
2 different motors sounds like you installed a motor with the vvt/cylinder deactivation which is not compatible with each other also i think the reluctor wheels are different inside the motor
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 01-12-2017, 01:46 PM   #3
71cadc10
71cadc10's Avatar
could you post a picture of the 2?
sounds to me like the 2013 is a VVT engine, the 08 was not.
sensor on the front cover, facing the right (looking from front) is the cam sensor. That would be same on both.
If the new engine has a sensor facing the other way, it would be for the cam phaser oil control valve (=VVT)
might be a little late, but to rectify it you could have changed the cam for a non VVT one. I believe the engine would run just fine that way then, with the 08 computer and tune file that's on it now
reluctor is same 58x
you need to change cam, front timing sprocket on the cam
both engines should have the cylinder deactivation (AFM)...so you can leave lifters in there if you want.
it would probably run with that same VVT cam, but not as well as it should...since that cam is cut to use the advance/retard functions the VVT gives it.
can't say I've ever tried that...to be sure how it would run.
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear
71cadc10 is offline   Reply With Quote
