01-11-2017, 05:54 PM | #1 |
Fabricate till you "puke"
Gen III vs gen IV
Help guys! I parted a 2006 silverado for builder parts, & I thought it was a gen IV engine. It is fly by wire, but the cam position sensor is at the rear of the block, like the 2000 engine in my 69. Plans are to have it bored 3mm, & build an iron LS1. I have not cracked the engine open yet, but my question .....is it a gen III, with 24 tooth crank reluctor wheel, or did they go 58 tooth on the wheel that yr? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
01-11-2017, 06:47 PM | #2 |
Re: Gen III vs gen IV
I thought 07 was the magic
number
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
01-11-2017, 07:16 PM | #3 |
It could be? I have read some much on the subject, that my head is verloaded' One read was the fly by wire throttle body went 58 t on the crank wheel.....but that should have the cam sensor up front? It looks to be a gen III....guess I will have to get a good day & crack it open. Thanks for the reply,longhorn
01-11-2017, 08:01 PM | #4 |
meowMEOWmeowMEOW
06.5, depending if it released as a Silverado "classic" or not, the engine could end up in a truck the following year.
GenIII ends at 06 (meaning IN 06) GenIV starts at 07 (meaning 07 model year) Yes, there can be anamolies and overlaps. 24t reluctor makes it GenIII electronics.
01-11-2017, 10:00 PM | #5 |
Thanks again guys....when I drop the pan, I will see Longhorn
01-11-2017, 10:06 PM | #6 |
Addicted to Rust
Aren't the gen 3 crank pos sensors black and the gen 4 gray?
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
01-12-2017, 12:08 AM | #7 |
If it's from a 2006 Silverado, it's a GenIII. The Silverado Classic was made concurrently with the new body style trucks in 2007, GM does that for some weird reason, they did it with the Malibu too. DBW started across the board in the Silverado line in 2003, with the V8 trucks, V6's stayed cable operated. GenIII engines will have the black 24x crank sensor and the GenIV will have the gray 58x sensor.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
01-12-2017, 09:54 AM | #8 |
This
Science flies you to the moon; Religion flies you into buildings. LeMans Turbo build http://ls1tech.com/forums/forced-ind...rbo-build.html C10 build (twin-turbo) http://www.performancetrucks.net/for...didate-501987/ |
01-12-2017, 01:36 PM | #9 |
you can also just pull the sensor and looky in the hole with a flashlight, if you don't want to pull the pan. 2 plates welded together with wide teeth = 24x
58x is a solid one piece plate The 06 GTO are one that's a oddity...everything looks Gen IV externally (DBW, knock sensors, cam sensor) but the crank sensor is black and if you peek in there they all have 24x cranks.
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear |
01-12-2017, 06:53 PM | #10 | |
01-12-2017, 09:38 PM | #11 | ||
meowMEOWmeowMEOW
The GENIII and GENIV use a slightly different internal architecture to their ECM systems. Basic things are the same (most simple sensors, DBW control is internal but functions the same), but the way the ECM's handle VE, PE, and things like trans controls are different. The 48t reluctor has a higher resolution (more teeth = more increments in one rotation= 4x more increments during a 4stroke power cycle). Is it "better"? From an engineering standpoint, yes. From a useage standpoint, you'll probably never notice.
01-14-2017, 07:31 PM | #12 |
Thanks again guys... I need to tear it down, & figure parts on the build. That or pony up for a low mile 6.0/add camshaft & go? Longhorn
01-14-2017, 08:36 PM | #13 |
Are 6.0s really that hard to find down south ?
There all over up here for $900 tops I try aand buy the whole truck for a $1000 part it out and get a free engine
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
01-15-2017, 07:51 PM | #14 |
In my area, the 6.0 engines seem to command a high price, even with 200-250,000 miles...(IMO, that is just a builder)? I have parted 2 trucks, & have 2 "free" 5.3 engines, One running in my 69, & one as a builder (285,000 miles). I may check the boneyards, as the long block 6.0 should be cheaper than a complete pull out. As we know, bigger is better on cubes....& the larger bores will make em breathe deeper! Thanks again....Longhorn
01-17-2017, 02:08 PM | #15 | |
flex fuel capability, easy to hook in. 24x reluctor...so would work with earlier engines out of trucks. Maybe you are right about avoiding it for swapping purposes...I'm not an expert on that but I do plan to get a project going here soon and will make a thread.
01-17-2017, 07:15 PM | #16 | |
meowMEOWmeowMEOW
01-17-2017, 09:31 PM | #17 |
I've got a perfect cam for a 6.0 over in the classifieds..... was going to put it in mine until I decided to build a stroker.
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
01-20-2017, 09:26 PM | #18 |
Thanks John....bad azz on the cam, but I dont know what i am building yet. longhorn
