01-19-2017, 03:05 PM | #1 |
Advanced Design, where did you mount your ECM?
I'm in the process of laying out what holes I will need in the firewall, and where to mount my ECM, boxes. I have the F.A.S.T., controllers. Will also add the TCI trans. control for my 4L60E.
I'm thinking about putting everything under the original bench seat. The battery will remain in the original, under floor location. Then running the main harness underneath the cab and to the engine. F.A.S.T. says to run their supply and ground wires directly to the battery, and they already have fuses in line. The rest of the trucks elec. system will be from a fuse box under the dash, and through the firewall, as original. I'm using American Autowire, Classic Update for that. Any ideas or advise, appreciated.
Steve. 1950 Chevy, 3100, built in Norwood Ohio, USA. My build thread, http://talk.classicparts.com/showthread.php?t=19110 |
01-19-2017, 03:54 PM | #2 |
Post Whore
Re: Advanced Design, where did you mount your ECM?
Absolutely you're on the right track...under or behind the seat..
01-19-2017, 10:19 PM | #3 |
Mines routed along the driver side frame rail, thru the floor to the back of the cab.
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
01-20-2017, 09:56 AM | #4 |
OK, Thanks, guys. I was thinking about making a raised mounting platform to mount them flat about an inch off of the floor.
After laying out the main harness, it appears, running it along the right frame rail to near the starter would be best. Then, possibly hide as much of the engine harness behind the fuel rails. Anyone else have pictures?
01-20-2017, 10:46 AM | #5 | |
How many inches, feet did you add to the harness?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
