01-20-2017, 10:30 PM | #1 |
Senior Moment
Found Temp sender that works with Original Gauge
NAPA Ecklin TS6666 sender works perfect with Original Gauge. You can get the 1/8 pipe adapter for the LS at Speedway.com . We hooked a real time scan to it and ran it for ~1/2 hour.
Sender is at the back of Passenger side head Pics tell the story Steve
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
01-21-2017, 07:34 AM | #2 |
Re: Found Temp sender that works with Original Gauge
Am I reading the gauge to be 201* in that position ?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
01-21-2017, 11:36 AM | #3 |
Senior Moment
yes, which would be very close to normal for an LS
01-21-2017, 09:49 PM | #4 |
I am glad someone finally got something simple to work, good job.
01-21-2017, 09:58 PM | #5 | |
Senior Moment
Steve
01-22-2017, 04:28 PM | #6 |
Would this work on my truck? 1978 C10, gathering parts for my 2002 5.3/4L60e swap.
01-22-2017, 06:04 PM | #7 |
01-22-2017, 11:22 PM | #8 | |
Senior Moment
Just my 2c
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 Last edited by 1970 CST Short Wide; 01-23-2017 at 01:28 AM. |
01-22-2017, 11:27 PM | #9 | |
Senior Moment
Good luck
01-23-2017, 09:00 AM | #10 |
If the picture you posted is what you consider "correct" and you're happy, then I suppose that's ok.
01-24-2017, 01:38 AM | #11 | |
Senior Moment
And YES I'm happy, are you?? KIS keep it simple
01-24-2017, 07:34 AM | #12 |
Thanks for taking the time to come.up with the correct sending unit. Its great to have a bolt in option..
We all know that a drill and tap can make the stock sender fit. I personally didn't want to chance messing up the head.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
01-26-2017, 01:37 AM | #13 |
Senior Moment
Especially if you try to do it in the truck. No fuss no muss this way
01-31-2017, 06:49 PM | #14 | |
Actually I guess you could always just add the correct resistance in series or parallel inline with the sender wire to put it exactly where you need it, regardless of the sender used.
1968 LWB C20 / AC / Wood Bed |
01-31-2017, 10:25 PM | #15 | |
Senior Moment
02-01-2017, 12:36 PM | #16 |
Speedway link to adapter
ECHLIN TS6666 1633.2 Ohms @100° 156.6 Ohms @ 220° I believe the stock gauge is 80 ohms being hot and 900 being cold. link to Napa catalog book The TS6655 on page 31 should put the gauge a bit more in the middle. I will buy and test one, some day project engine is still sitting next to the truck with 1087 Ohms @100° and 111 Ohms @220° Awesome find 1970 CTS Short Wide Last edited by binford; 02-01-2017 at 12:50 PM. |
02-01-2017, 10:34 PM | #17 | |
Senior Moment
01-08-2018, 09:32 AM | #18 |
You are the man! Ive got NVU gauges and trying to find the adapter to use their sender, Your post definitely helped!!
05-17-2018, 09:19 AM | #19 |
Auto Meter 2277 Adapter
Note: I.D. of this adapter where the sender probe will go through is .309 and would require drilling to approximately 5/16" or .312 for a Stewart Warner sender to pass through. TS6666 WILL NOT CLEAR center bore (Must drill !)
1967 C10 SWB Owner - Rustbelt Restorations |
05-17-2018, 10:17 AM | #20 |
FWIW here's a graph of the stock sender. If someone wanted to compare it to this one, that'd be handy data!
Somewhere I have a graph I actually plotted on my own in the kitchen with a thermometer and my own sender...
05-17-2018, 01:57 PM | #21 |
I found a pdf of an Eichlin - Engine Management Reference Guide and these are the specs it had listed for the TS6666
TS6666 1 threaded stud 156.6Ω@220°F, 1633.2Ω @100°F 1/8 x 27 Dryseal |
05-21-2018, 09:34 PM | #22 |
thanks for the info!!!
