Old 01-26-2017, 04:35 PM   #1
Ironhorse
Ironhorse's Avatar
Everything To Convert to Std
Have nearly all the main pieces to convert from auto to standard. Clutch fork, adjustment rod, thru the firewall rod, engine side ball stud (2wd V-8) and the bell crank or z-bar. Brake and clutch assembly with brake rod. All the main pieces to convert to standard shift except for the frame bracket. Can do more pics if needed, just let me know. Open to reasonable offers, money order only, do not have Paypal.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Last edited by Ironhorse; 02-16-2017 at 05:56 PM. Reason: removed price, open to offers
Ironhorse is offline   Reply With Quote
Old 01-28-2017, 10:28 AM   #2
Ironhorse
Ironhorse's Avatar
Re: Everything To Convert to Std
Saturday morning bump
Wellington, Ks
Old 01-31-2017, 03:12 PM   #3
Ironhorse
Ironhorse's Avatar
Going from auto to standard, here's the parts you need. Open to reasonable offers, money order, do not have Paypal.
Wellington, Ks
Old 02-05-2017, 06:08 PM   #4
Ironhorse
Ironhorse's Avatar
Super Bowl Sunday bump
Wellington, Ks
Old 02-11-2017, 10:24 AM   #5
Ironhorse
Ironhorse's Avatar
Still have this, somebody needs it. Let's make a deal, open to reasonable offers.
Wellington, Ks
Old 02-16-2017, 05:54 PM   #6
Ironhorse
Ironhorse's Avatar
ttt
Wellington, Ks
Old 02-16-2017, 08:34 PM   #7
chevycc1970
chevycc1970's Avatar
Does that clutch adjustment rod happen to be for a 4wd?
chevycc1970 is offline   Reply With Quote
Old 02-16-2017, 11:00 PM   #8
Ironhorse
Ironhorse's Avatar
It is for a 2wd, the 4wd version has a wedge shaped fitting that fits up against the clutch fork.
Wellington, Ks
Old 02-16-2017, 11:27 PM   #9
chevycc1970
Yes the wedge will fit on both 2 and 4 wheel drive. I was merely wanting to know if it was longer for the 4wd application.
Old 02-17-2017, 10:40 AM   #10
Ironhorse
Ironhorse's Avatar
The clutch adjustment rod measures 13 3/8" in length. Hope that helps your question.
Wellington, Ks
Old 02-19-2017, 02:15 PM   #11
Ironhorse
Ironhorse's Avatar
Lot of views, no takers? Don't need this since I went to auto, open to reasonable offers.
Wellington, Ks
Old 10-16-2021, 08:37 PM   #12
tinman_local2
I know this is an old post, but do you still have these for sale?
tinman_local2 is offline   Reply With Quote
Old 10-16-2021, 09:42 PM   #13
Ironhorse
Ironhorse's Avatar
All those parts are long gone but.......may have another clutch/brake set up. Will have to check the parts stash and get back to you. No clutch fork, rods, z-bar or other items left I know.
Wellington, Ks
Old 10-17-2021, 08:05 AM   #14
tinman_local2
I really just needed the upper pushrod that passes through the firewall and goes to the z-bar.
Old 10-17-2021, 08:56 AM   #15
Ironhorse
Ironhorse's Avatar
The clutch rod I know I don't have. Might keep a watch on the parts forum for one but be aware.....pretty sure there is a difference between the clutch rod for the IL6 and the V8 engines. Might want to look into that, I don't have any experience with an IL6 in these trucks but thinking I read that here at some time. Good luck in your search.
Wellington, Ks
Old 02-03-2022, 02:07 PM   #16
Drew1968
Drew1968's Avatar
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
Drew1968 is offline   Reply With Quote
Old 02-03-2022, 04:46 PM   #17
BigBird05
I have some of the Manual trans parts. PM me and i'll go look for them.
BigBird05 is offline   Reply With Quote
Old 02-03-2022, 08:35 PM   #18
Drew1968
Drew1968's Avatar
If you need any further assistance with that please contact any Administrator for help.
Old 02-04-2022, 08:59 AM   #19
A1971Blazer
A1971Blazer's Avatar
I have the cross member that the bell housing bolts to if anyone might need it
Also I am a supporting member...
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
