Old 01-30-2017, 04:30 PM   #1
jricharc
GM aluminum intake weld EGR or block it
I have a GM aluminum intake I pulled from my '76 Vette and I was going to put it on a C10 I recently picked up. I want to delete the EGR and the hot air choke outlets but is welding a good option or should I use block off plates? I don't care about keeping it stock and my uncle can weld it for me for a few beers. I just wasn't sure if there were any drawbacks to welding them up.
1986 C10 LWB 350
1970 C10 LWB 350 - Sold
jricharc is offline   Reply With Quote
Old 01-30-2017, 05:05 PM   #2
BossHogg69
motor exploder
BossHogg69's Avatar
Re: GM aluminum intake weld EGR or block it
I would just use a block off plate if it were me. I'm definitely not saying your uncle can't do it, but old, dirty, porous cast aluminum isn't the most fun thing to weld.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 01-30-2017, 06:04 PM   #3
jricharc
That's what I figured, I was trying to make it look a little better but I will just get some plates and paint them to blend into the manifold.
1986 C10 LWB 350
Old 01-31-2017, 02:27 PM   #4
61K10
61K10's Avatar
If you don't want to make one--many after market ones.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
aluminum, egr, intake, weld
