Old 02-06-2017, 09:15 PM   #1
JDO AK
LS Swap in 4x4 71 longbed
I just bought my second C10 and this one is for my son. I'm planning a LS swap and would like to know what kind of suggestions people have on a few things
Looking for better gas mileage
Looking for reliability
I was thinking a 5.3 or 4.8 with a 4L60 is this a good choice?
Also will a T-case from a earliy 2000 motor tranny 4x4 work as well as long as I use a manual shift?
I wanted to change the 4:10 rear end to 3:73 posi any options either way?
Thanks,
Justin
JDO AK is offline   Reply With Quote
Old 02-06-2017, 11:22 PM   #2
57taskforce
All about them K’s
57taskforce's Avatar
Re: LS Swap in 4x4 71 longbed
Can't help you on the ls swap but the transfer case is a no go if you've got a Chevy front axle under it. With The later cases the front driveshaft drops on the wrong side.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is offline   Reply With Quote
Old 02-07-2017, 01:29 PM   #3
bs46488
Justin,
I did an LS swap in another project.
The biggest factor for me was what I could easily find available. I ended up with a 5.3 with 4L60 and ECU pull out. I followed the instructions on lt1swap.com for the wiring harness and had no problems.
It fires up and goes straight to idle every single time.
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914
1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161
bs46488 is offline   Reply With Quote
4x4 build, c10 1971, ls swap
