Old 02-17-2017, 11:15 AM   #1
wishmasstir
Rear interior panels
Are the rear interior side panels the same for all years? I need a set to start with and found a set from a 79 but I have a 75.
wishmasstir is offline   Reply With Quote
Old 02-17-2017, 01:49 PM   #2
Bigred74k20
Bigred74k20's Avatar
Re: Rear interior panels
73-77 the bed went to the front seats and in 78 they moved the bed back away from the seats to have a foot well for the rear passengers. I would go on eBay and look at some 77+ K5s and see if you can find a picture of the inside rear panels.
1974 Chevrolet K5 Blazer
350/Th400/205 Dana 60/14 Bolt
36x12-16 S.S TSL Radials
6"Front 7.5"Rear F/R ORD bushings/front shackles
Sky shackle flip, Crossover, rear disc brake conversion
ORD steering box brace, Tom woods CV rear driveshaft
Bigred74k20 is offline   Reply With Quote
Old 02-17-2017, 02:39 PM   #3
wishmasstir
I've been searching, I couldn't find anything definitive. Only thing I have to from is that the panels I found used look like they'll fit my 75.
Old 02-18-2017, 03:45 PM   #4
Bigred74k20
I currently have some panels from a 76 that are in bad shape. If you could provide some measurements, I can compare the two.
Old 02-18-2017, 11:28 PM   #5
Fishermen0105
I think they changed in '78. I was thinking prior to that they had some sort of vinyl with wood trim but can't remember. Mine are all a vinyl type material on my '79.
Fishermen0105 is offline   Reply With Quote
Old 02-21-2017, 03:12 PM   #6
wishmasstir
So I found out that I dont have any software on the computer to compress the file size so the pictures are smaller than they should be.
I know that I don't have all the brackets to bolt the panels down but i'll make some.
