Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 02-20-2017, 11:58 PM   #1
79vette
FS: Lots of Gauges and Cluster Parts
I have about 15 clusters worth of gauges, circuits, housings, and misc. pieces. All years/styles, from 73-91. All are used, pulled from local salvage yards. Condition ranges from near-mint to fair driver quality.
I have voltmeters, ammeters, temp gauges, fuel gauges, speedo heads, a few clocks, housings, circuit boards, PRDNL indicators, and tons of the little lens parts (turn signal/4WD/choke/etc). There are a few of the fiber optic ashtray lights in good shape. I dont have any really clear plastic lenses or good clean gauge bezels, but I have most of the other parts.
Post if you want anything and I will put up pics. I'm new around here, but I've been selling these on ebay for a couple years with good feedback. Ebay name "WasatchChevyParts" http://www.ebay.com/usr/wasatchchevyparts
1988 "Crane Truck" C30 - 350, SM465, with a 15' knuckle crane - thread
1986 M1009 - 6.2 Diesel, SM465, 2 speed aux trans, NP205 - thread
1979 Corvette - 350 T5
1977 Jimmy - 350, TH400, NP203
1982 Blazer - 350, 700R4, NP208 - Totalled, now a parts truck
Scratch built 16' flatbed trailer - thread
79vette is offline   Reply With Quote
Old 02-21-2017, 12:02 PM   #2
1978 Cheyenne Big 10
Re: FS: Lots of Gauges and Cluster Parts
Hello,
I am looking for a clock and Gauge Cluster Clear Lens w/ Clock Option and rubber grommet.
Early Design 73-78. Clock stem is at 12
Mike
shipping is to GA 30519
*1978 C10 Cheyenne Big 10. Matching Numbers Block, 355/Turbo 350. 12 Bolt 342 Posi, 186 Double Hump Heads
*1972 Chevelle. 406-6" Rods/Turbo 350 TCI kit, 12 Bolt narrowed, 456 Full Spool, C-Clip Eliminator, 8pt Roll Cage
*1979 C10 Scottsdale. Matching Numbers, all original, 350/Turbo 350. 12 Bolt 308
1978 Cheyenne Big 10 is offline   Reply With Quote
Old 02-21-2017, 04:19 PM   #3
TKCR
TKCR's Avatar
Originally Posted by 1978 Cheyenne Big 10 View Post
Hello,
Mike
This is his eBay ad:
http://www.ebay.com/itm/73-87-OEM-Ch...VYq9o~&vxp=mtr
Old 02-21-2017, 08:32 PM   #4
K25alive
Do you have a 6432019 fuel gauge? This is the small fuel gauge with orange needle. It only shows the word FUEL on the face.
K25alive is offline   Reply With Quote
Old 02-22-2017, 02:15 AM   #5
79vette
Sorry, I dont have any of the small type fuel gauges. Only the larger type for the non-tach clusters.
Hello,
I do have the clock; the link TKCR posted is correct. It is in good shape, except the screw that holds the knob on. The third pic on the listing shows it is damaged. The clock can be adjusted fine as-is and the screw is removable, but it is irritating to take it out. Price is negotiable on account of that.
I also have the lens that came with that clock, but it isnt super nice. The rubber grommet is dried out and hard and the lower right mounting point is broken off. The other 5 are still there. There is not any noticeable hazing or discoloration in the lens and I would consider it suitable for a driver, but it has a lot of light scratches in it. I will get some pics up tomorrow.
Old 02-22-2017, 08:30 PM   #6
Sent you a PM
thanks
Old 02-24-2017, 06:12 PM   #7
79vette
Sent you a PM
I couldn't figure out how to get the pics to display right in a PM, so here they are. The lenses are really hard to photograph accurately, so I threw a partial cluster together from random parts to try to get an idea of how it would look with gauges behind it.
The clock isnt in the pic because it wouldnt fit in this non-clock green housing, but note the hole in the lens at the 12-oclock position where the adjustment rod comes though.
Old 02-25-2017, 10:55 AM   #8
GonicGM
GonicGM's Avatar
Would be interested in a damage free 1987 cluster housing, gauges, no tach or clock. Also any good tach cluster printed circuits, any year.
83 K30 SRW 350 TH400 NP205 4.10 9' Fisher
85 K30 SRW 350 TH400 NP205 4.10
87 V3500 Dually 454 TBI SM465 NP205 4.10 9' Fisher
83 K2500 350 TH700R4 8600GVW Dual Tank 4.10
1973 Cheyenne Super 30 DRW Std Cab Z83 4.10
1976 Silverado C30 Std Cab 4.10 DRW (4 sale)
GonicGM is offline   Reply With Quote
Old 02-25-2017, 11:00 AM   #9
GonicGM
GonicGM's Avatar
Also orange pointer and screw retained cable.
Old 02-25-2017, 12:49 PM   #10
79vette
I have some orange pointers with the screw cables. Do you need the metal plate with the shift pattern as well, or just the pointer?
I believe the 1987 clusters had the cable for the speedo cable on the speedometer itself, not on the housing like the earlier ones. I will check for a damage free unit, and get back with pictures if I have one.
Unfortunately I don't have any tach printed circuits, sorry.
Old 02-26-2017, 01:40 AM   #11
79vette
Lens and 73-79 clock are sold. 1978 Cheyenne Big 10, your package will be on its way Monday morning.
Still have one of the later style clocks (80s), and lots of other stuff. Housings, circuits, lots of gauges and little plastic lenses (turn signals, 4WD, etc)
Old 02-27-2017, 09:39 PM   #12
flatbed82
Do you have any housings for a tachometer cluster without broken tabs?
flatbed82 is offline   Reply With Quote
Old 02-27-2017, 10:00 PM   #13
79vette
Sorry, I dont have any parts for tach clusters.
Old 03-02-2017, 10:23 PM   #14
Received the clock and lens today!
Just as described and fast shipping.
Thank you
Mike
Old 03-03-2017, 03:08 AM   #15
79vette
Sounds good! Let me know if you have any problems getting the clock to fit into your housing, or with anything else. Thanks again.
Old 03-09-2017, 03:34 PM   #16
87Scotty
I am looking for just the second hand for a clock. Do you have a broken/non working clock that I could buy the second hand from?
Thanks,
87Scotty
87Scotty is offline   Reply With Quote
Old 03-09-2017, 04:15 PM   #17
79vette
Unfortunately not. All the clocks went fast. I'll keep you in mind if I do come across one though.
Old 03-14-2017, 08:06 PM   #18
TBONE1964
Cluster King
TBONE1964's Avatar
Do you have any volt gauges? Both styles are OK (76-80 and 81-87) as long as they work. Not worried about cosmetic condition.
Let me know.
Thank you,
Tom
TBONE1964 is offline   Reply With Quote
Old 03-14-2017, 11:05 PM   #19
79vette
I think you might have got a hold of me through ebay last week, but I'm not sure. I'm WasatchChevyParts on ebay.
I do have a bunch of volt gauges; most are in reasonable cosmetic condition except one that is missing its pointer. They are not tested at this time, but I will test prior to shipping. I have 10 or so between both styles, and they are all in good cosmetic condition and are most likely working.
Let me know how many you need, and I will test them for you.
Old 03-15-2017, 12:37 AM   #20
TBONE1964
Cluster King
TBONE1964's Avatar
Good to know you are a member here and I will get with you when I need some. Yes it was me inquiring on eBay.
Take care,
Tom
Old 03-15-2017, 03:08 PM   #21
capone550
Do you have any clear lenses without the clock or trip reset?
capone550 is offline   Reply With Quote
Old 04-04-2017, 05:07 AM   #22
Olive1970
Olive1970's Avatar
Do you have any known working speedo heads for a 1977?
Gary
Slowly looking for my next 67-72 truck
Olive1970 is offline   Reply With Quote
Old 04-05-2017, 06:18 AM   #23
tanman722001
tanman722001's Avatar
Hi I'm looking for a fuel gauge for my 84 Chevy. Let me know price
1991 GMC K2500 4X4 350/auto
1991 Chevy S10 ext cab.
1990 Chevy S10
1993 Chevy S10 Blazer 4dr 4.3 Vortex/Auto
tanman722001 is offline   Reply With Quote
Old 04-05-2017, 06:58 AM   #24
RWJJR
RWJJR's Avatar
Interested in a orange pointer , pm me a price shipped to 37840.
1980 Silverado short bed
1993 GMC 1500 LS swap
2006 Lifted Z71 Crew Cab
RWJJR is offline   Reply With Quote
Old 04-08-2017, 06:44 PM   #25
79vette
I've been travelling and catching up on work, and haven't been on the forum for awhile. Note to anyone looking at my ebay listings: DON'T buy anything through ebay unless you really want to, as I can do lower prices selling through the forum (no ebay fees, associated hassle, etc).
_______________________________________________________________________________________________
I have a couple good ones. None are "like-new" but are what I would consider good driver quality. They are as nice or nicer than what is in the truck I drive everyday. I will get some pictures up tomorrow afternoon.
I have one left that I was going to use to convert my 82 to the earlier style gauges, but I am being pretty lazy on that. The needle needs painted, but it is otherwise in good shape. I set it aside on account of the particularly nice face, knowing I could paint the needle. $55 shipped in the lower 48?
http://www.ebay.com/itm/272623971361
I have a few. See links for the face styles I have. I can do $30 shipped for either gas one, 40 for the diesel.
http://www.ebay.com/itm/282426454518
http://www.ebay.com/itm/282426453778
http://www.ebay.com/itm/272623993011
I dont have any of the gear shift pointers right now, but I can keep an eye out for one. Is that what you need?
