03-06-2017, 06:36 PM | #1 |
Engine Identification
Hi,
I'v just bought a 56' chevy pickup shortbed and plan on rebuilding the engine and sprucing the truck up a little. I am having trouble identifying what inline 6 the truck has. I'v found the casting numbers (3994257 GM66) and checked certain databases but can still not identify it. Can anyone help? Photos here: (https://www.dropbox.com/sh/qbxo8dw0d...5YkkQm9La?dl=0) Thanks! |
03-06-2017, 06:48 PM | #2 |
Re: Engine Identification
Looks like 67-72 250
03-06-2017, 06:51 PM | #3 |
230 or 250 chevy six cylinder.
Look here for specifics. https://en.wikipedia.org/wiki/Chevro...aight-6_engine |
03-06-2017, 11:34 PM | #4 |
Yep, with the points style distributor it should be 1974 or earlier and a 194, 230 or 250 with the short side covers.
If there is a suffix code on the engine number stamped into the pad on the side of the block by the distributor that may be the key to figuring out what it came out of.
03-08-2017, 11:38 AM | #5 |
I read somewhere that you can tell whether its a 230 or 250 by looking at the crank pulley or piston heads. I think I'll just pull off the valves to have a look.
Thanks for the help everyone. Much appreciated! |
03-08-2017, 03:37 PM | #6 |
Copy down or get a good photo of the engine number that is stamped in the pad next to the distributor an I'll try to decode it.
The good thing is that most pieces interchange outside of some size specific parts. The casting number sheets show that 8994256 is the casting number for most 292 blocks. Being one number off doesn't jive as your engine has the short side covers and the fuel pump is in front of the motor mount boss. Here is a shot of my 68 292 with the tall side covers and the fuel pump behind the right side motor mount.
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 03-08-2017 at 03:57 PM. |
03-08-2017, 04:04 PM | #7 |
I did find this link that shows a similar engine that was posted on here at one time. http://67-72chevytrucks.com/vboard/a...1&d=1316317720
Hunting down a photo that engine compartment is a 65/66 Chevy Nova engine compartment with the spring towers. I have a feeling that your engine code stamped in the pad on the block is going to match either the 1965 or 1966 engine codes listed here. http://www.novaresource.org/codes.htm
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 03-08-2017 at 04:24 PM. |
Tags |
chevy, inline, truck |
