Saginaw PS pump pressure valve
Hello everyone.
Ive got all of the accessories off of the front of my 350. The power steering pump is shot, so I'm planning on keeping the original housing and putting new pump in it to save costs. Is it recommended to replace the power steering pressure relief valve at the same time? I have had a hard time trying to find a new one for sale. I don't think there quite replacement parts. Someone told me that if your rebuilding the pump, I need to change the valve as well. The old pump was notchy and groaned very loud when I had the motor running. What is the protocol for these old saginaw pumps. Thanks -Gavin |
Re: Saginaw PS pump pressure valve
I wouldn't worry about it. It's a very simple little valve. I'd replace the o-ring on it and re-use it. If you're worried about it just spray it good with brake parts cleaner and let it dry.
This link will show you what it looks like inside. http://www.gmtruckcentral.com/articl...rsteeringmods/
1997 ECSB K1500: 350; NV4500; 3.42's; 14 Bolt SF; 0411 ECM; 3/4-ton Calipers; Hydroboost; 3500HD Door Handles; 32x11.50x15 Cooper STT's on OOBS Rallys Plans: 4.10s, 33's, 4" Lift, Urethane Bushing Kit |
Tags |
power steering, saginaw |
