03-12-2017, 08:55 AM | #1 |
Will a 1965 GMC 19500 GVW Cab fit a 1965 Chevy C-10?
I came across a solid original 1965 GMC stripped cab that I am thinking of purchasing as a replacement for my rusty 1965 Chevy C10 cab. I cannot find out anything on this cab, but it has a VIN number of "V4008 F12345E" From what I can tell, the "E" stands for GVW of 19500. This is supported by a GMC sticker on the firewall stating the truck was 19,500 GVW. Aside from that, I cannot find anything on the VIN and don't know what kind of truck this came from.
That aside, attached are two pictures of the cab - the interior dash is different, but I can remove mine and install it - if that is the only difference?? On the exterior, the hole for the steering column is circular and there is a bar across the transmission hump. Also the inner fender well mounts are a bit different. Does anyone know if this cab would be a good candidate for a replacing my C-10 Cab (with minor modifications)? It "appears" to be dimensionally correct to my C-10, but couldn't spend a lot of time measuring. I am just comparing pictures. Any help, as always, is appreciated. Lastly, what would be an honest price for this cab? |
03-12-2017, 09:31 AM | #2 |
Re: Will a 1965 GMC 19500 GVW Cab fit a 1965 Chevy C-10?
Yes, it will fit, the steering column hole is definitely different but cut and patch yours in there.
03-12-2017, 09:54 AM | #3 |
You can find me on Instagram @neveno_cten |
03-12-2017, 12:34 PM | #4 |
Dont know if you have tried here for info:
http://6066gmcguy.com/VinNumber.html Looks like a solid cab as big trucks alot of the times are. Something to consider is how would you title it? GMC or Chevrolet? I have a bare 65/66 GMC cab so if you need any reference pics or measurements, just let me know. |
03-12-2017, 11:23 PM | #5 |
60-66 Nut
One other difference is that the GMC cab is setup for a hydraulic clutch. That may or may not make a difference depending on what you are planning for the brakes. All of those minor differences are definitely workable.
