Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 03-12-2017, 08:31 PM   #1
Old Radio Tech
Rear Differential
1965 Burb, 4wd, has TH700R AT, NP208C Transfer, front differential is Dana 44 3.73 , the only number I can find on the rear is F174 right side bottom as facing the cover. Looking for help identifying rear differential.
Old Radio Tech is offline   Reply With Quote
Old 03-12-2017, 11:43 PM   #2
Captainfab
60-66 Nut
Re: Rear Differential
I have no idea what the F174 is but your rear differential should be a 12 bolt. That is what would have originally been under a '65 1/2 ton 4x4 Suburban. Is the Dana 44 front a closed knuckle with drum brakes, or an open knuckle with discs?
Old 03-13-2017, 02:23 AM   #3
Old Radio Tech
front is a Dana 44 5F , closed knuckle with drum brakes. Not at the shop now so can't count the rear, but I'm sure it's at least 12 bolt, but it's a different casting than the front. And the numbers aren't located in the same place as the front.
