Old 03-15-2017, 01:21 PM   #1
Adam4pt6
69 c20 lowering questions
1st off I'm sorry, I know this is beat to death, and I did search but most everything is referring to a c10. But my question is pretty straight forward. How low can I go with out a c notch? I won't be hauling anything at all with the truck. I plan on Staying 8 lug and keeping the rear (eaton I believe?) I have. It's also coils all around. Will the larger rear limit me any?
The plan is drop spindles (disc conversion), Springs and new shocks all around, and a block in the rear if need be. I'm assuming I'll need an adjustable Panhard bar and rear shock relocations as well. I can switch to smaller bumpstops if needed. I'll be running steel wheels off of a 90s suburban, and am flexible on tire size (open to suggestions).
So what's the lowest I can go? Am I missing anything in my parts list? Thanks guys
Adam4pt6 is offline   Reply With Quote
Old 03-15-2017, 04:32 PM   #2
demian5
demian5's Avatar
Re: 69 c20 lowering questions
Measure the distance between the top of the axle and the frame rail. Then subtract at least 2 inches for suspension travel and that would be a safe way to estimate.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 03-15-2017, 05:15 PM   #3
Adam4pt6
That's a good point, and obviously easy to do. I won't be around the truck unail later so I'm just curious what every one else has gotten away with
Old 03-15-2017, 05:15 PM   #4
JustToxic
JustToxic's Avatar
GMC Pauls makes drop springs for our C20 trucks and POL make disc brake drop spindles for our trucks as well. So with that, you can drop as much as your heart desires. I personally wouldn't drop it lower then 4" in the rear without a c-notch. For the front if you drop it 3" or more with springs then you'll need a camber adjustment upper control arm cross shaft. Without doing more modifications to the C20 best bet would be doing a 2/4 drop with springs, or a 2 1/2" front drop with spindles and a 4" drop rear with springs.
1967 Chevy C20 to K20 Conversion "Simply Toxic"
http://67-72chevytrucks.com/vboard/s...d.php?t=749409
1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775
JustToxic is offline   Reply With Quote
Old 03-15-2017, 06:14 PM   #5
Adam4pt6
Also, on the measurement idea...how accurate is that really? Think about it... 50 year old springs...there's probably some sag going on there. It may already sit a little lower then factory...making the measurement for new lowering Springs possibly off... right?
Old 03-15-2017, 06:23 PM   #6
Adam4pt6
Just checked them out. What's the difference between c10 and c20 Springs? I was under the impression I could just run Springs marketed for the c10, is that incorrect?
Old 03-15-2017, 07:11 PM   #7
northerngmc
northerngmc's Avatar
I used C10 springs in my C20 when I lowered it. Worked well. 2" front, 4" rear. Left it with stock drum brakes.
Biggest problem I had was most threads said to simply pop the lower ball joint open and swing the brakes out of the way to swap the front springs. Popping the ball joint took some work and then the brake backing plate would not clear the suspension and come out. So I ended up unbolting the lower control arm from the frame.
Pics for reference on 2" front and 4" rear C10 Springs.
Before.....
After....
I did take measurements on the top of the fender lip to the garage floor before and after and it was close to 2"/4" on the tape.
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 03-15-2017, 07:13 PM   #8
Adam4pt6
Thanks man those pictures are helpful
Old 03-15-2017, 11:53 PM   #9
Jose's 69
I used c10 4" lowering springs and a 1.5" block in the back. 2.5" drop spindles and 1 inch drop springs in front. Converted to front disc brakes in the process. I would like to go another inch lower in the back but not sure if I can without the rear end hitting the bed.
Jose's 69 is offline   Reply With Quote
Old 03-16-2017, 08:39 AM   #10
JustToxic
JustToxic's Avatar
If you still want to use the C20 as a C20 then you'd want the slightly heavier duty springs. But if your like most of us with C20's then you can use C10 springs. The C10 spring will give you a smoother ride compared to a C20 spring.
Old 03-16-2017, 09:15 AM   #11
Adam4pt6
Any chance you can snap a few pictures of your truck for me? I like the stance of yours, but do you have a picture of a straight on side view? And would you be able to take a picture showing axle to frame clearance?
Old 03-16-2017, 09:16 AM   #12
Adam4pt6
So basically a c20 lowering spring will be stiffer and have less travel then a c10 spring?
Old 03-16-2017, 09:18 AM   #13
JustToxic
JustToxic's Avatar
Suspension travel will be close to the same it'll just be a stiffer ride.
Old 03-16-2017, 09:20 AM   #14
Adam4pt6
What I'm getting at is, with the c20 spring there will be less of a chance bottoming out on smaller bumpstops and such as there would be with the softer c10 spring...correct?
Old 03-16-2017, 09:24 AM   #15
JustToxic
JustToxic's Avatar
Since your not wanting to do a c-notch, yes the C20 springs would be less chance of bottoming out.
Old 03-16-2017, 10:19 AM   #16
Jose's 69
Sure no problem. I'll try to get some pics uploaded later.
Old 03-16-2017, 12:37 PM   #17
Adam4pt6
Thanks man I appreciate it
Old 03-16-2017, 01:01 PM   #18
Jose's 69
Ok. Here's a couple of shots. Hope they help. I have about 3 inches before the axle hits frame in the rear bit I think the pumpkin is closer to hitting the bed.
Old 03-16-2017, 01:04 PM   #19
JustToxic
JustToxic's Avatar
That's a good looking C20.
Old 03-16-2017, 01:19 PM   #20
Jose's 69
Thank you. I'm swapping in a newer 350 with vortec heads off a 92 2500 this weekend hopefully. After that, replace the wood bed and I should be done... for now. Ha.
Old 03-16-2017, 02:35 PM   #21
azle
This low.... Sorry just saw C20 this is a 10 obviously...
azle is offline   Reply With Quote
Old 03-16-2017, 04:38 PM   #22
Spullar
So exactly how low is that?
Spullar is offline   Reply With Quote
Old 03-16-2017, 07:50 PM   #23
Boog
laying low
Boog's Avatar
Here ya go Joe. It's easier on the neck.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 03-16-2017, 09:24 PM   #24
Jose's 69
Hahaha. Thanks. I had no idea how that happened.
Old 03-20-2017, 10:30 AM   #25
azle
That is rear differential sitting on frame on 1 inch rubber blocks and front A arms sitting on modified rubber bushing, also about 1 inch. That is fully slammed not driving stance. Kind of new to the BAG world but I run 60psi on both front and back to drive, it is still low. Hope that helps.
Azle
