Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 03-27-2017, 07:38 PM   #1
ironman3452
ironman3452's Avatar
64 C30 1 ton panel
ok I need help, I have looked at every catalog put out, with no luck, my 64 chevy C30 1 ton panel, needs a new fuel sender, does any one here know of a replacement?, here is a picture of the unitName:  fuel sending unit 64 C30 panel.jpg
Name:  top of fuel sending unit 64 C30 panel.jpg
Size:  48.2 KB and as far as I can tell no one makes one, even the parts place , say they have one, it is for a truck, not a 1 ton panel.
ironman3452 is offline   Reply With Quote
Old 04-01-2017, 05:08 PM   #2
ironman3452
Re: 64 C30 1 ton panel
well after a lot of cleaning, and CLR, the sending unit is operational, looks like I will be getting ready to put the tank back in and getting her ready to go for a drive.
Old 04-03-2017, 01:57 PM   #3
65chevysub
65chevysub's Avatar
I just replaced the one in my 65 Suburban with one from Classic Industries. They say its for 60-66 Sub/Panel. Works great. Hope the pic coned out so you can see it.
65chevysub is offline   Reply With Quote
Old 04-04-2017, 12:26 AM   #4
Captainfab
60-66 Nut
The '63-'66 sending units are not the same as the '60-'62 sending units. Those are attached to the tank with 5 screws.
Old 04-08-2017, 03:09 PM   #5
ironman3452
ok you have a fuel tank in the back of your sub, mine is just behind the driver and on the frame, mine if you would have looked has 5 holes, not a clamp, and yours is longer
Old 04-08-2017, 03:13 PM   #6
ironman3452
I have 2 fuel sending units, both said that they were for a 60- 66 panel or sub, what I found out is that theses are for 1/2 ton and subs, not for a 1 ton panel, so you have to be careful when ordering parts, you need to tell them that you have a 1/2 ton or 1 ton\, if it is a truck, or panel.
Old 04-08-2017, 11:10 PM   #7
padresag
they both may have the same size tank though
ron
padresag is offline   Reply With Quote
Old 04-09-2017, 06:03 PM   #8
ironman3452
Size:  43.8 KBpadresag, do you have the dimentions of your tank?
mine is 9 and 1/2 inches tall, by 32 and a 1/2 inches long, by 16 inches wide, do this seem to be the same size as yours?
Old 04-09-2017, 06:05 PM   #9
ironman3452
or does any one else have a picture of there 1 ton panel or 1/2 or 3/4 ton sub tank, I can tell you they are not the same, just look at the difference between my 1 ton, and the 1//2 or 3/4 ton sub.
Old 04-09-2017, 07:01 PM   #10
padresag
these are what orig tanks look like
ron
Old 04-09-2017, 07:10 PM   #11
ironman3452
see what I mean yours is nothing like mine, but I did get my sending unit to work, so I am going to reinstall it and fill it and see if it will do what I want, if the sending unit does not work, I am going to make a newer sending unit work, I have the length of my old one and can bend a new one to match, will let you all know how it works.
Old 04-10-2017, 12:50 AM   #12
Captainfab
60-66 Nut
Ron, I have not seen a C30 panel have a rear tank like the C/K10 Suburbans and panels did. They had a tank mounted alongside the frame a little ways behind the drivers side door. Not sure just why, but that is what I have seen them have.
ron
Old 04-10-2017, 02:05 AM   #13
padresag
thank you
ron
Old 04-10-2017, 07:25 PM   #14
ironman3452
that's what i was talking about and even put my tank in the pictures, so ever one can see what a C 30 1 ton panel, gas rank looks like and what kind of sending unit, it has in it.
Old 04-11-2017, 11:45 AM   #15
cg285
ironman is correct. my 1 ton 64 is the same. i plan on robbing parts off a new sender and fixing mine.
cg285 is offline   Reply With Quote
Old 04-13-2017, 09:40 PM   #16
ironman3452
ron
yes for a rear gas tank,
Old 04-13-2017, 09:45 PM   #17
ironman3452
ron
yes for your 1/2 or 3/4 ton panel, or sub.
Old 04-14-2017, 12:11 AM   #18
padresag
that onlt makes 5 times that I have been told . is there a problem
ron
Old 04-14-2017, 12:13 AM   #19
padresag
they didn't make a 3/4t panel or suburban
ron
Old 04-14-2017, 05:18 PM   #20
ironman3452
hey RON , in 1965 gm did make a 3/4 ton, but I do not know if it was only for that year, sorry I did not mean to sound like I was mad or anything like that, just I tried to show every one here what I was going thru to get my gas tank ready to go back in, again sorry if I sounded like I was mad.
Last edited by ironman3452; 04-14-2017 at 05:39 PM. Reason: editing wrong spelled words
Old 04-14-2017, 05:46 PM   #21
ironman3452
GM did make a 3/4 sub, it was in 1965 and not sure if it was for only that year, does any one here know of a 3/4 panel/ or suburban, I would like to know, thanks for looking.
Old 04-14-2017, 06:48 PM   #22
padresag
1967 was the first year to offer a 3/4 ton
ron
