04-11-2017, 11:12 AM | #1 |
1968 396 power steering reservoir mount photos
I'm looking for photos showing the location where the bracket mounts on the fender. I searched and couldn't find any good photos. Thanks in advance for any help.
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod |
04-11-2017, 11:25 AM | #2 |
Re: 1968 396 power steering reservoir mount photos
My 68 GMC big block
04-11-2017, 11:55 AM | #3 |
Thanks for the photo. I could only find photos with the bracket leading towards the fender. How is the bracket mounted? Are there nuts welded to the core support?
04-11-2017, 12:01 PM | #4 |
I have never seen the reservoir mounted there and don't think its factory.
04-11-2017, 12:10 PM | #5 |
04-11-2017, 12:43 PM | #6 |
Not the best pic but I had to screen shoot a video.
04-11-2017, 02:14 PM | #7 |
Interesting. I have only seen them mounted to the drivers side fender in 68. But like ghalperin said I have not seen many pics. I am working on building 68 bb replica so am also interested in more pics.
kwmech is that a factory set up?
68 c10 swb stepper 68 c10 swb stepper 67 c10 lwb 06 gmc duramax |
04-11-2017, 02:19 PM | #8 |
It that a picture of your truck? Would you mind getting a measurement were that bracket is located from the core support?
Sorry OP hope I am not hijacking.
04-11-2017, 02:25 PM | #9 |
LH fender on my 402 trucks. Two vertical holes located approx. 1" rear the LH gusset I think it's called, which mounts the top front corner of the fender and core support. The bolts insert from inside the fender. Bolts are 1/2" head tapered with integrated washers. The screw threads are 5/16-18 x 7/8.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
04-11-2017, 02:47 PM | #10 |
I'll take some more pics this evening when I get home.
04-11-2017, 03:53 PM | #11 | |
Pic of the 68 longhorn |
04-11-2017, 10:11 PM | #12 |
Roadtrip!
This is the only way I have ever seen a 68 setup.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
04-11-2017, 10:53 PM | #13 |
That would be great.
04-11-2017, 10:59 PM | #14 |
My former 68 was set up just like ChaseBBC's pic. It was a factory 396 truck.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
04-12-2017, 06:25 AM | #15 |
Not 100% sure if this is factory but it is a original 396 truck
04-30-2017, 02:38 PM | #16 |
My 72 Cheyenne 402 Big Block has it directly mounted to the fender just like KWMECH in the above pic, I believe it is factory for 72. I'm currently restoring my reservoir but will post pics when done.
Last edited by Cesar Diaz; 04-30-2017 at 02:39 PM. Reason: referenced incorrect pic |
04-30-2017, 02:54 PM | #17 |
At the body shop.
I just looked my '68 with a 454 has no reservoir.
Too grubby for a decent pic
" That didnt make it any newer " " Dont antique the equipment " |
05-01-2017, 02:06 AM | #18 |
When you get a chance, could you measure the distance between the front bolt on the hinge to the bolt on the reservoir mount? Center to center.
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod Last edited by ghalperin; 05-01-2017 at 10:56 AM. |
05-01-2017, 09:57 AM | #19 |
^^X2 would also like to know.
06-27-2017, 05:09 PM | #20 |
I found this in the assembly manual.
