Old 04-19-2017, 02:50 PM   #1
wolfsden
wolfsden's Avatar
Molding trim
Is the white section in the side molding trim part of the trim or is it the side panels ( body parts) painted white?
I'm using this pic as an example.
Thanks.
1963 Chevrolet C-10
wolfsden is offline   Reply With Quote
Old 04-19-2017, 02:59 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Molding trim
Paint. Here is my truck right after the white was sprayed...
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 04-19-2017, 06:36 PM   #3
ImpalaJim
ImpalaJim's Avatar
Re: Molding trim
body then there is 2 lines of trim that meet!
ImpalaJim is offline   Reply With Quote
Old 04-20-2017, 09:28 AM   #4
corvettejim1968
corvettejim1968's Avatar
Re: Molding trim
the body is painted white.
i think Mar-K sell the trim
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 04-24-2017, 07:43 PM   #5
wolfsden
wolfsden's Avatar
Re: Molding trim
Thank you
Can you tell me how wide the white stripe is without the molding? I want to paint mine.
1963 Chevrolet C-10
Old 04-24-2017, 07:46 PM   #6
wolfsden
wolfsden's Avatar
Re: Molding trim
Thank you.
I want to paint the white line can you tell me how wide it is and how high up to start?
1963 Chevrolet C-10
Old 04-24-2017, 07:48 PM   #7
wolfsden
wolfsden's Avatar
Re: Molding trim
Thank you
1963 Chevrolet C-10
Old 04-24-2017, 08:28 PM   #8
cru_zn_29
cru_zn_29's Avatar
Re: Molding trim
The white stripe should be about 2 1/2". If you measure your mounting hole distance between top and bottom holes is 2 1/2" Hope this helps.
cru_zn_29 is offline   Reply With Quote
Old 04-24-2017, 09:41 PM   #9
wolfsden
wolfsden's Avatar
Re: Molding trim
i don't have any holes, there was no molding on my truck. I just bought a molding kit from classic industries and there are no directions.
I would rather not drill holes and use 3m tape , I remember reading somewhere how to do it with some sort of plastic spacers needed but i can not find the head anymore.
1963 Chevrolet C-10
Old 04-25-2017, 08:22 AM   #10
Raked 64
Raked 64's Avatar
Re: Molding trim
here you go
http://67-72chevytrucks.com/vboard/s...+trim+mounting
1964 C-10 short bed
406 small block
700R4, 4:11 gears
20" wheels
Raked 64 is offline   Reply With Quote
Old 04-25-2017, 08:56 AM   #11
wolfsden
wolfsden's Avatar
Re: Molding trim
Originally Posted by Raked 64 View Post
Thank you!
1963 Chevrolet C-10
