Old 10-20-2003, 10:11 AM   #1
lugnut
lugnut's Avatar
tranny/tc probems
Is is possible for tranny fluid to enter the T/C? My tranny has been giving me problems lately and actually is out as we speak. I notice a leak from the T/C and thought I had a bad front output shaft seal. When I went to drain the fluid to replace the seal in the T/C the thing was overfull by almost two quarts-the leak that I thought was the front seal ended up being fluid pumping out the top of the breather tube on the T/C. The tranny was low almost the same amount so it has to have come from there...it is practically impossibe to overfill a T/C because once it starts coming out the top filler hole, its full. If tranny fluid did get in the T/C does that mean the front seal on the T/C is damaged or does the pressure just force it in or what? Any comments? GM Is installing a new tranny today for me. I installed a GM reman 10,000 miles ago and it has been junk ever since so GM is replacing it today for me, so they are aware of the T/C fluid situation as well-I just want a second opinion.
1967 Chevrolet 1/2 ton 4x4
1972 GMC 1/2 ton 4x4
2005 1500 4x4 Suburban
2004 GMC Envoy 4x4 (wife's)
lugnut is offline   Reply With Quote
Old 10-21-2003, 07:59 AM   #2
eaglelox
Member Dude
eaglelox's Avatar
sounds like a bad seal. i cant think of a good way to overfill a t\c with out a bad being the culprit.
Steve
1978 K20 Burb, 4" lift, 33's, 350
Eaglelox@Hotmail.com
eaglelox is offline   Reply With Quote
Old 11-09-2003, 01:42 PM   #3
adot
Had the same problem. My problem was a bad front T/C seal. When my tranny would get hot the fluid would pass through the rear tranny shaft and leak into the T/C, then the T/C would build up pressure and shoot it out the vent tube. This is a very common problem. Replace the T/C seal and you should be good to go!
1990 GMC SUBURBAN MSD 6A MSD DIST. HELIX TBI SPACER
adot is offline   Reply With Quote
Old 11-09-2003, 01:45 PM   #4
adot
BTW.. forgot to mention I burn't my tranny up because of this problem!
