04-23-2017, 01:05 PM | #1 |
Replacing the flexplate without removing engine or transmission
I thought some of you may enjoy these pictures. I replaced the flexplate without removing engine or transmission. My truck is a 1969 CST/10 with 350 engine and TH400 automatic transmission. I am a newbie for such an in-depth repair, so if I can do it anybody can. Some of you may recall a recent post of mine where I talked about chewing up my flexplate and needing to replace it.
First of all, the research. I found this interesting forum article: https://ls1tech.com/forums/automatic...l#post18644698 The only special tool I ordered for the job was a Lisle Flywheel Turner. I highly recommend this tool, it is just great. https://www.amazon.com/dp/B000FN7JE2/ I did some things slightly different than the article. I did not remove the driveshaft. Instead I just took loose the rear u-joint and the carrier bearing mount bolts, and rested the driveshaft on a strap so it could move front to rear with the transmission. I disconnected the negative lead of the battery. Instead of removing the starter, I just loosened the inner bolt and remove the outer bolt, and rotated the starter out of the way. I removed the parking brake cable guide that is right behind the transmission and pushed it up the cable and out of the way, and put a small bolt and nut in place, and hooked the cable under it. It is out of the way for when the transmission moves back. This picture shows the transmission already moved back. I took out the flexplate-to-torque-converter bolts with help of the flywheel turner tool. I removed the various transmission connections and mount bolts. I put in the 4 long bolts one at a time, and took out the top 2 transmission bolts. I put a jack under the transmission to lift just a little bit of weight. It probably wasn't mandatory, but I thought it was a good idea. The truck was on ramps for the operation. My Home Depot was out of 4 inch 3/8 grade 8 bolts, so I got some 5 inch bolts. It worked great. The transmission slid back on those bolts with little effort, and what I saw was a big work area to get at the flexplate-to-engine bolts. Here is what the flywheel turner tool looks like. Last edited by dmjlambert; 04-23-2017 at 01:09 PM. Reason: Corrected the order in which I did some of the steps |
04-23-2017, 01:14 PM | #2 |
Re: Replacing the flexplate without removing engine or transmission
Look's like you have it under control. Good talking with you today. Good luck with the truck it looks like a keeper.
04-23-2017, 01:19 PM | #3 |
Nice Job! Bravo!
I have done that many times and I learned something today, glad I clicked on the post, never thought to use long bolts to slide it back on, I always pushed it back and propped it up with wood and such across the frame rails. I also like that you left the driveshaft in, much less mess and no fluid lost! |
04-23-2017, 01:20 PM | #4 |
Oh and where did you get the flywheel turning tool? My snap-on one is just like that except a different handle, wouldn't mind getting another one if it were reasonably priced.
04-23-2017, 01:26 PM | #5 | |
Just click and a couple days later here comes the tool. |
04-23-2017, 01:37 PM | #6 | |
Do you know you can ratchet with it on the flywheel to get the proper span of teeth? I jam the tooth attached to the handle in the flywheel the move the handle to engage another tooth with the springed portion, then turn the flywheel, makes it quick to engage when rotating the flywheel to line up the bolts. Another tip you may not know...each of the holes in the flywheel are elongated, 2 are the same elongated around the circumference. One is 90 degree opposite elongated. (from the center of the crank outwards) If you install that bolt first you can fully tighten it then when you turn the flywheel the others will line up because they are elongated around the circumference for the bolt to line up. Saves time as you don't have to start all the bolts before tightening them up. |
04-23-2017, 02:54 PM | #7 |
I didn't know that. Good info, thanks.
04-23-2017, 07:30 PM | #8 |
Works on old chevy,not newer dodge.I had rear seal go on 2005 dodge ram 4x4.Tried this.Did not work out as well. Congrads on working around extra work.
Only the stupid know too much to learn something new. |
04-23-2017, 09:11 PM | #9 |
I'm in the process of doing the same thing. I've done it before. I'm replacing the starter and flexplate ate the same time.
04-23-2017, 09:23 PM | #10 |
Great post !!
I haven't had the pleasure..... yet . Looks like the deal. Time saver and like Randy said , much less fluid loss. Thanks for the info. |
04-24-2017, 11:21 AM | #11 |
That's a great tip with using the five inch bolts to keep things lined up.
I didn't do that when I replaced mine. It sure will make things easier. |
04-24-2017, 11:44 AM | #12 | ||
"I ain't nobody, dork."
All I would add is use a piece of wood, like a 3/4" piece of ply wood about 12" x 12" between that transmission pan and the floor jack.
Good job! Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
04-24-2017, 11:44 AM | #13 |
My dad and I did it on my 73 BB 2WD suburban. Not too hard, just needed enough room for hands and a torque wrench.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
04-24-2017, 12:10 PM | #14 |
I did the same last year...drop drive shaft at diff, unbolt tranny at crossmember, 4 long bolts, slide tranny back & wala. Used the same tool also.
1970 C10 Short Stepper with 71/72 front clip. |
04-24-2017, 05:57 PM | #15 |
The longer bolt thing is a good idea. We used to run into a lot of 2000ish s10s with cracked flexplates at my old job. I just took all the bolts out and backed the top 2 halfway out and just let the gap happen. Had just enough room to get in there with box end wrenches.
10-06-2018, 09:29 PM | #16 |
I have a 72 coming tomorrow. PO said the ring gear needs to be replaced and I started researching how to do it and found this post. First off, thanks! So I've seen ring gear can be purchased separately but feel you may as well replace flexplate with ring gear at the same time. Do you recall where you bought your flexplate?
10-07-2018, 10:57 AM | #17 | |
Proprietor of Dale's Corner
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
10-07-2018, 12:07 PM | #18 |
I got mine through Amazon:
https://www.amazon.com/gp/product/B000C8RDCS/ I compared them when I took the old one off, and the new one was exactly the same. |
11-17-2018, 05:48 PM | #19 |
Was this on a 2 wheel drive truck? I'm attempting this on a four wheel drive Blazer which with the transfer case may make it more difficult.
11-17-2018, 05:56 PM | #20 |
Moderator
The fact you could just remove one starter support bolt and turn the starter tells me the support bracket at the end of the starter is not in place...
I would make sure the starter support bracket is in place at the end of the starter when you put it back together.... These missing support plates are the number one reason the starters break out the outer mounting bolt hole in the ear on the block. Nice work on the flex plate R&R ...
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
11-17-2018, 06:56 PM | #21 |
It is 2 wheel drive truck, no transfer case. I do suppose it would be different for a 4 wheel drive truck. In 1969 there was no additional support bracket for the starter on trucks. I would like to get one anyway before I do anything to the timing that could cause kickback.
11-17-2018, 07:04 PM | #22 |
Moderator
Make sure the block is tapped for the bracket then...I just checked my 69...it has the bracket, as does my 67....maybe previous owners had em fitted...
11-17-2018, 07:42 PM | #23 |
Is this what the one I need looks like? I have the original style starter with diagonal mount holes, and 168 tooth flex plate.
11-17-2018, 09:45 PM | #24 |
Moderator
Thats the bracket....it bolts to one of the starter thru bolts, the one with the extended threaded section
There should be a threaded hole just above the oil pan rail approx at end of starter. The block also appears to be drilled for both offset and straight bolt pattern...
11-18-2018, 12:26 AM | #25 |
OK, thanks. I ordered one just now. When it comes in I'll crawl up under there with a hand full of different bolts and wrench, and have a look around and try to bolt it in place. I've been meaning to do this because I know they are a super good idea.
Tags |
flexplate, flywheel |
