Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 05-01-2017, 02:04 PM   #1
rainamy
Parting out 1976 c10 Silverado & Cleaning Up Sale - More parts added 5/3
Looking to trade or sell the left over pieces of a parts truck we used. Cab is decent and has a clear title if anyone needed a cab for their truck, might consider selling that.
Some of the stuff left on it:
350/4bbl Radiator - $35
Radiator shroud - $20
Newer replacement vacuum booster $40
Master cylinder - $20
A/C condenser - $20
Hood hinges (pair) - $40
3pc chevy cab band set - $40
Tailgate band - sold
15" aluminum rims with worn tires - $225
Complete lwb 2wd frame with all suspension, 12 bolt rear (gear unknown) - $250
Silverado style LH blue door panel -sold
Base model RH blue door panel $20
Tailgate $75
78-80 front bumper with brackets, slight bend should be straightened easy $30
Hood, looks to (possibly) have the start of a bend in one spot $30
Front bumper guards $75
Holley aluminum body dual feed elect choke carb $125
Holley regular cast elect choke 4bbl carb $90
Quadrajet core elect choke $35
Plastic 8' bedliner $35
Dash Pad (cracks) $40
Everything would be plus shipping, but, you're welcome to pick it up as well in Conyers GA, 30012. Open to trading for good no dent no rust sheetmetal, or some other wish list stuff for the project truck.
Last edited by rainamy; 06-18-2017 at 08:52 AM. Reason: Adding images 5/1; Adding Parts 5/3; Editing parts & prices 6/6; updating sold items 6/11
rainamy is offline   Reply With Quote
Old 05-01-2017, 03:23 PM   #2
DarkKnightWong
Re: Parting out 1976 c10 Silverado & Cleaning Up Sale
Hi
Are you parting out the suspension pieces?
Im looking for the two rectangle shims on the upper control arms.
They are flat one one side and curved on the other.
I can take a picture if it helps.
Im in Dunwoody.
Allen
DarkKnightWong is offline   Reply With Quote
Old 05-01-2017, 05:52 PM   #3
rainamy
Hi Allen,
As far as the suspension goes, really just looking to sell the whole setup altogether - likely to someone looking to modernize an earlier truck, convert 6 lug to 5 lug, etc. Not going to be taking that apart and getting stuck junking most of the pieces after.
Thanks for the interest though.
Old 05-01-2017, 06:10 PM   #4
cajundragger
how clean are the doors?
how much for all the wood grain dash pieces? basically everything around the column?
condition of the rear cab trim band?
cajundragger is offline   Reply With Quote
Old 05-01-2017, 08:15 PM   #5
Sabaka454
Sabaka454's Avatar
Also interested in interior pieces, dash bezel, trim, wheel, etc
Sabaka454 is offline   Reply With Quote
Old 05-01-2017, 09:23 PM   #6
rainamy
* The original 73-76 doors aren't good from what I recall. When we bought this thing it came with 2 extra sets of doors beyond what's on the truck - a total of (2) sets 73-76 type and (1) set 77-up type. The original driver door to the truck is dented beyond repair. The other (3) 73-76 types have rust at the bottoms, and at least one had a speaker hole cut. If you were interested in some to weld/restore using patch panels on the bottoms, I'd give you a cheap deal on your choice of them - otherwise i expect to gut them for vent windows, handles, etc. The 77-87 look to have been power, but the PO appears to have removed a bunch of stuff from the driver side at the least. 77-up drivers has dents, passenger doesnt, and nether looked to have rust....
* the woodgrain dash stuff I'll try to get better pics and going over on. I know the dash bezel was cut at the radio by the PO, so its either a donor for the wood overlay, or for someone running a non-shaft radio at this point. I also believe the upper right corner had a crack in the black plastic behind the wood. I can try pulling some off, take pics of the defects, and if you're still interested try to set a price based on how it looks off the truck?
* the cab trim has faded paint, is the basic chevy logo, but didn't appear to have dents/dings when I looked it over on Sunday.
Old 05-01-2017, 09:26 PM   #7
rainamy
I'll put you second in line on the dash pieces.
The wood insert on the steering wheel would need to be restored, it is faded with some wear to it. I can get you some better pictures, not sure how nice you're looking for?
What other interior and trim were you interested in?
Old 05-02-2017, 08:36 AM   #8
cajundragger
Yeah I guess take it off and we'll see what it looks like? If I don't take it, I'm sure someone else will?
I remove the inquires about the doors and rear trim.
My only interest is the wood grain dash bezel- depending its condition.
Old 05-02-2017, 12:13 PM   #9
HunterRotten
HunterRotten's Avatar
I want those impact strips on the front bumper, pm me some pics and a price!
HunterRotten is offline   Reply With Quote
Old 05-02-2017, 12:16 PM   #10
HunterRotten
I re-read the ad and saw later bumper. Do you mean for an 81+? I'm looking for impact strips for a original 1978 bumper.
Old 05-02-2017, 02:23 PM   #11
TKCR
TKCR's Avatar
Does the tailgate band have dings/dents or major scratches?
Old 05-02-2017, 05:11 PM   #12
rainamy
This was an 81+ style bumper.
Old 05-02-2017, 05:14 PM   #13
rainamy
I'll check it out better for you and try to get some better pictures. If memory serves, it was pretty nice. I also have another one around here that needs to be polished out and didn't have any dents/deep scratches, but, need to think where I stuck it.
Old 05-03-2017, 02:28 AM   #14
TKCR
TKCR's Avatar
Yeah let me know on both.
Old 05-03-2017, 01:21 PM   #15
rainamy
Pictures of the speedometer cluster bezel. Note the cut out radio area, circled crack in the black plastic of upper right corner, small piece of the excess material on LH edge wore off, and a slight distortion upwards at one screwhole.
Old 05-03-2017, 01:28 PM   #16
rainamy
A/C bezel in dash, note a couple shallow dents in woodgrain, a bent edge by vent, and some scracked nest to emblem.
Emblem appears to be spoken for and is not included.
Old 05-03-2017, 01:29 PM   #17
rainamy
2 piece driveshaft:
Old 05-03-2017, 05:15 PM   #18
rainamy
Front Bumper Guards:
Old 05-03-2017, 05:27 PM   #19
rainamy
The one on the truck had issues to where I don't think it'd be much good. Here's pics of the black one. It looks to have no dents or scratches, but there is one spot where looking at the right angle it looks like there is a slight wave in it (maybe). Highlighted it with a red arrow in a picture.
Old 05-03-2017, 05:39 PM   #20
TKCR
TKCR's Avatar
Sending PM
Old 05-04-2017, 12:16 PM   #21
HunterRotten
Can I see a close up pic on the bumper guards chrome finish? I'm also looking for a body color round gas cap if you have one.
Old 05-04-2017, 12:25 PM   #22
mongoose45056
I would be interested in the front bumper (even with the small dents!) and the two impact strips as well. Let me know how much for the complete setup. Thank you.
mongoose45056 is offline   Reply With Quote
Old 05-04-2017, 06:06 PM   #23
rainamy
Complete front bumper with strips and mounting brackets I was asking $75, plus shipping. If you don't need the brackets make it $50 plus shipping.
Old 05-04-2017, 06:44 PM   #24
rainamy
Chrome is notoriously hard to photograph. These are typical gm production quality for the era. There are usual bumps in the finish, rough area on the bottom facing parts of the guard near the ground underneath the chrome, the occaisional scratch or pit. They a nice deep color, haven't faded to silver, and probably would clean up with polish to be nicer. There is one larger defect I tried to zoom in on in the picture, runs inward in an arc about 1.5" long off the edge that you should be able to see.
Old 05-09-2017, 08:03 PM   #25
Super_Dave
Super_Dave's Avatar
Steering column?
Tilt?
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair
"Life is tough - wear a cup!"
"Old Enough to Know Better - Too Young to Resist"
"Junk is something you will need three weeks after you throw it away."
Super_Dave is offline   Reply With Quote
