05-01-2017, 07:30 PM | #1 |
Lower Ball Joint - testing my patience - picts
Hi Guys,
I'm prepping to install my 4/6 drop and I'm rebuilding my lowers and I'm trying to figure out how to get these SOBs out. I have taken a grinder to them wacked on them, put heat and nothing yet. It looks at though there is a collar that holds it on. Does anyone have any insight? Am I on the right path or have I totally frigged this up? I originally gave these to a shop to do but they sat on the job and told me at least another week and 200 bucks so I'm trying this out on my own. Thanks
Found my dad's old truck http://67-72chevytrucks.com/vboard/s...d.php?t=563321 Newspaper Article Publishing the quest find my dad's old truck http://www.theglobeandmail.com/globe...ticle12494281/ |
05-01-2017, 07:40 PM | #2 |
Re: Lower Ball Joint - testing my patience - picts
Damn just watched a youtube vid and I was way off with the removal of this...rookie mistake
https://www.youtube.com/watch?v=Wj5P7enwTU0
05-02-2017, 10:55 AM | #3 |
Wow I am suprised you were able to get the center out of the ball joint like that. You can rent that tool from Autozone that was featured in the youtube video. Pressing them in is a little harder with that tool but is possible. You could save yourself time and take off lower control arm and just take to shop and have them press it in for you
79 Chevy 2wd BIG10 350 TH400 |
05-02-2017, 01:02 PM | #4 |
Yeah I was persistent.
After renting this tool from Canadian Tire it came out so easily I could have done it in the parking lot. Now onto the bushings
05-02-2017, 07:07 PM | #5 |
Just the same was, just in reverse for putting back in. bushing ball joints.
Glad you got them out.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
05-02-2017, 09:27 PM | #6 |
...just another truck junkie..
I rented that tool from my local O'Reilly's to do the ball joints when I had my '71. Then I bought it. Handy thing. Actually did the ball joints in the parking lot of my apartment building on a Saturday morning.
Mike "Bear" Shea |
05-03-2017, 08:20 AM | #7 |
Did mine a few months back. They weren't as crusty as yours so I got one out with a 3lb hammer and used that same tool for the other. The tool is def the way to go!!
05-03-2017, 08:21 AM | #8 |
05-03-2017, 09:17 AM | #9 |
I got the problem solver moog replacements so when I get to that point I'll figure out how to put them in...it looks like you have to drill them in though.
I wrestled with the bushings for a couple of hours and decided to take it to another shop that specialized in restorations. I drilled, torched banged with a hammer and those suckers weren't moving.
05-03-2017, 03:53 PM | #10 |
Well looks like I'm getting raked over the coals with my bushing replacement.
$254.35 to take the old bushings out, it took them 3 hours and had never done it before...some classic car restoration shop...must have been a slow day for them.
05-03-2017, 08:32 PM | #11 |
Robert Olson Transport
I have a 14 ram 2500 and bent two of those kits for the ball joints.. one was a chinacrap and the other was a matco one... wound up torching them until the ball popped (sounded like a gunshot) and then we were able to press out the old ones and that was on the lowers truck has 116K on it
05-04-2017, 09:58 AM | #12 |
I just about refuse to spend that much at a shop unless i absolutely cannot do the work myself. after i finished all my front suspension, steering and brakes I took truck to firestone for front end alignment paying the $96 bucks had me feeling bad!! I got poly control bushings for $60 from parts geek and ball joint for $20 from rock auto, rented the tool from orielly and just fought it till i got it done. It did take awhile and i had to walk away a couple times but eventually got it finished.
05-04-2017, 04:51 PM | #13 |
I took mine to a local shop and he charged me $100 to push em in and out. After buying the ball joints and bushings and paying to have em pushed in the $250 each for new lower control arms (complete) from Rock Auto doesn't seem too bad now.
"Life is too short to drive a boring vehicle". Later, Wayne |
05-05-2017, 09:24 AM | #14 |
That crossed my mind also but I wanted to do the work myself to learn how all that works.
05-05-2017, 09:40 AM | #15 |
I find that when doing any bushings or pressing heat is your friend.
05-06-2017, 07:19 AM | #16 |
Its funny how different these trucks can be. When i did the ball joints on my C10 last summer the bottom ones took me a whole 10 minutes each. had one of those ball joint kits they popped right out with a good bit of pressure then i popped the new ones right in.
one of the top ones took me longer than both the bottoms combined God bless air chisels
- When the Reaper makes his deal, trust in your steel - '77 C10 350/350 2/4 drop and a mild street engine |
05-06-2017, 12:26 PM | #17 |
When MOOG offers a "Problem Solver" part - buy it: they are fixing an inherent problem, and it's a wise purchase.
The new ball joint ~should~ go it just fine with that kit. The same ball joint kit often goes on sale at Princess Auto. Current retail is $109, I might have paid $60 a number of years ago. Doing all poly bushings on a vehicle usually takes me 6 to 8 hours. I usually use an Oxy-Acetyelene torch to burn out the rubber, or if I don't have a torch, a drill and a LOT of patience. A hydraulic press is VERY handy for putting the new bushings in, and Princess Auto has a 12Ton that usually goes on sale for about $135 (retail $189). Often, I will buy the tool to do it myself, if the tool even approaches the labour to pay someone else to do it for me. Then the tool has paid for itself, and the rest of the jobs are free! One of my mottos: "I can pay a professional to screw it up, or I can screw it up myself for free."
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
05-07-2017, 05:24 PM | #18 |
Interesting. I like how you put it I never thought about it like that before.
