05-04-2017, 04:21 AM | #1 |
What is wrong here?
Can anyone anwser my question i have about these untrustworthy looking motor mounts i got going on here?
Im in a slightly bad mood tonight as i just got done cracking a new windshield installed in my 71 blazer too. heaven forbid anything go right nowadays. thanks, skip |
05-04-2017, 04:25 AM | #2 |
Re: What is wrong here?
pic of windshield i f-ed up since i mentioned it.
05-04-2017, 07:12 AM | #3 | |
Sux on the wind shield
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
05-04-2017, 10:27 AM | #4 |
Looks like you found that missing cylinder head bolt.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
05-04-2017, 12:48 PM | #5 |
Are you saying these are the wrong part number? Just seems like they would contact more on the frame side. Looks like they hole further back would. Be the right one but then why they dont line up i know the bolts are too long i just grabbed what i had laying around tell i can figure this out. Damn u orielys auto parts!
!whats the corrrect part number this is all they listed |
05-05-2017, 04:11 AM | #6 |
measured from spring shackle eye on frame to crossmember for trans, the passanger side is 1 inch closer to the front, thats the most off mount too for the motor. looks like theres holes to move it back, drivers side was 13" passanger side was 14!
why would someone put the passanger side closer to the front seems crazy. gonna loosen motor mounts up and unbolts the tcase isolators and trans crossmember and slide it back to the other set of holes on just the passanger side. see what happens. maybe the last owner was a drunk mechanic or something. |
05-05-2017, 09:46 AM | #7 |
Look at the lite side - - at least you don't have the chrome trim in your windshield gasket which makes it a lot easier to change
4oldcars Driving: 1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado The ones I let go: 1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed |
05-09-2017, 05:19 AM | #8 |
moved the passanger side mount for tcase and trans back and wala! everything lines up perfect. wonder how long the fool before me ran it like that.. duh..
