Old 05-11-2017, 08:36 AM   #1
zach_carver
zach_carver's Avatar
1965 4 wheel disc brakes
I wanna see if you guys have ever heard anything like the situation I am currently having. Ill try and sum it up. My truck has front and rear disc brakes with new master/booster and disc/disc prop valve. I have no brake fluid leaks! My truck has a perfect brake pedal until I hook up my vacuum to my brake booster. When I plug in my vacuum my pedal goes all the way to the floor with slight resistance. However Ive been driving the truck with it unhooked and it does fine. It all started after i replaced booster/master and installed rear disc. Anyone ever seen such??
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 05-11-2017, 11:07 AM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: 1965 4 wheel disc brakes
Likely a bad booster. My buddy has done his '72 Nova and '68 C10 with CPP boosters and in both cases, they were bad right out of the box. Had them replaced under warranty and the replacements worked perfect.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 05-11-2017, 11:47 AM   #3
zach_carver
My booster is a MBM booster off ebay. But they already sent me another one and it changed nothing. Does changing booster size (diameter) matter any? I have a smaller booster than I did before.
Old 05-11-2017, 02:00 PM   #4
PGSigns
PGSigns's Avatar
I would say there is still some air. The added brake line pressure from the booster is able to better compress it over the manual brakes.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-11-2017, 10:25 PM   #5
zach_carver
Jimmy
I have bled probably 3 pints of brake fluid through. I was getting solid fluid through it at the end. But Idk maybe I should try it again. It's crazy though because the pedals fine until I hook booster up. Then goes to the floor.
Old 05-12-2017, 06:34 AM   #6
PGSigns
PGSigns's Avatar
So there are two ways a master cylinder will go to the floor, air or its bad.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 05-12-2017, 07:17 AM   #7
zach_carver
Jimmy
Could my bore size being too big or too small have any effect? I guess I need to get another master cylinder.
Old 05-14-2017, 10:41 PM   #8
jweb
jweb's Avatar
Have you tried adjusting the push rod on your booster?
Here's a link to the CPP trouble shooting guide. There's a tool they recommend for checking the length
http://www.classicperform.com/TechBo...ot.htm#pushrod
jweb is offline   Reply With Quote
Old 05-15-2017, 07:40 AM   #9
zach_carver
Yea my booster and master are correct. Im unfamiliar with the tool though? My master is deep and I had to add a piece between my booster because it was shallow. I added a piece that was included with booster/master. Ive seen some people talking about drilling the hole 1" lower in pedal but I havent tried that yet. I wasnt sure it would cure the issue I am having.
Old 05-16-2017, 12:29 PM   #10
zach_carver
Does brake booster size have any affect? My old booster was HUGE compared to this 8 or 9" I have now..
Old 05-16-2017, 06:21 PM   #11
jweb
jweb's Avatar
Most Disc/Disc set ups I have seen use an 8" dual booster and 1 1/8 bore master cylinder. Do you know what size your master cylinder is?
Here's a helpful article about Booster/Master cylinder combos:
http://www.mpbrakes.com/techtalk/boo...ur-classic-car
Old 05-17-2017, 07:25 AM   #12
zach_carver
No I dont know my bore size.. The guy I brought from off ebay is not much help. He wont even respond to me now. I cant seem to find mine even in 1 1/8 bore for sale anywhere so idk if they even make it in that bore. Im about to the point to just order a new different master cylinder and try that. Im lost lol
Old 05-17-2017, 09:24 AM   #13
jweb
jweb's Avatar
I would just go to your local parts store and buy a master cylinder for a late 60s or early 70s Corvette with power brakes. Those years of Corvette have 4 wheel disc and a 1 1/8 master. Only about $35 but I think they are shallow so your booster pin may need to be changed
Old 05-17-2017, 09:47 AM   #14
zach_carver
I think ill try this. Thanks man! Ive got the different adapters for shallow and deep pocket masters. Thanks will report back
Old 05-17-2017, 10:18 AM   #15
jweb
jweb's Avatar
Don't forget to bench bleed the master before installing.
I hope this helps, good luck.
Old 05-17-2017, 08:11 PM   #16
zach_carver
Thanks man, will do!
