Stock horn notes?
I added a set of the old Cadillac four-note optional "Train" horns, which if I understand correctly, as the notes F, A, D, and C. I get cut off a lot at the roundabout by my house, but didn't want a non-stock airhorn setup on my truck, so this was the compromise.
I decided to keep my existing two horns connected, just to see what it'd sound like, and it sounded good, so I left all 6. Besides being a load on the relay, I'm sure, it all seems to work. That surprised me, because if the factory horns (my truck has the dual horns) weren't in the same scale, it'd sound like garbage. So they must be in the same key? Or part of the same chord? I'm not a musician... Anyway, was just wondering if anyone knows: a) What note(s) the stock horns produce b) Why it sounds good when mixed with Cadillac F, A, D and C horns Last I looked they were just indicated as "high" and "low" notes. My guess is that the 67-72 truck horns are actually already one of those notes, like C, so it's just making that part of the chord louder and thus not interfering with it.
![]() Join Date: Jan 2001
Re: Stock horn notes?
That's an interesting combination. I've looked at it several ways, and it seems to be an F6 chord. It's kind of a jazz chord. Maybe someone at Cadillac was a fan.
what year and model cadillac did you get the horns from....?
I got the horns by note on eBay, not sure what year. I assume late 70s since it's still a packard connector on the horn, not yet Weatherpack.
I like my Hella twin air horns right behind the grill. Very effective.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
thanks dave
My 1975 Pontiac's horns are very authoritative.......I'd like to have something similar on my truck.
Then there is this..... https://www.youtube.com/watch?v=icnRMW6P9nc |
Post Whore
![]() ![]() Join Date: May 2015
Train horns are a nice "touch"
#10 | |
I installed it because my first intersection is a roundabout which it seems only about 60% of the people understand! I get cut off there regularly and would like to warn rather than test my braking!
#11 | |
It's a shame because they work so well on the GM Proving Grounds, when you are interacting with a group of professional drivers. Public roadways - not so much. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#12 | |
(lol) My '63 GP horns were not working so my original idea was to add some GMT800 horns as a replacement. While messing around with them I got the original horns working, so I played around with combinations of one, two three and four. Ended up keeping all of them for most volume (and effect). K
#13 |
I've always wondered if my horns are stock because they sound incredibly dinky - NOT what I would expect from a big long bed 3/4 ton truck. I'd like to find some attention-grabbing US made horns.
-Jim 71 Chevrolet C20 94 GMC Yukon 4x4 ![]() |
#14 |
![]() Join Date: Feb 2002
I've got Fiamm Freeway Blaster horns, a Hi-Low set up, on my '71 GMC Jimmy.
I call them the F U horns. US-made, at least mine were. Fit right in where the GM hi lo's went. Louder than stock, but not a train horn or air horn. http://www.aerostich.com/fiamm-freew...ster-horn.html On my '68 C/10 Stepside, the OEM single horn burned out. I think it was in the key of "C". I had an old Mercedes Benz horn, .c. 1960-70s, amongst my parts collection. I had to grind off the angle bracket from the burnt out GM horn and run a separate ground for the negative terminal [ground not being normalled to the body of the German horn]. It sounds funny coming from a Chevrolet truck, but is annoyingly loud, and gets their attention. Kind of a ''Meep-Meeep!''
#15 |
I put a set of 4 caddy horns on my 71 last year. Sounds really good to me. I got them in the older than 2000 section at my local pick your part....... mounted them to the inner fender, 2 on each side with relays
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#16 | |
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI |
#17 |
Who Changed This?
![]() Join Date: Jan 2013
One horn is an "A"; the other note is open for debate, but probably the higher note of the two. I have a thread going about that, but there is nothing definite about the sound, as yet. I'm thinking about going to the "local" "Pick Your Part", which is about 20 miles away, and get some horns like Andy mentioned- from a Cadillac. The local yard (3 miles away) had exactly ZERO horns. I don't know how that guy makes a living! All this for something I use maybe 2 or 3X a year. How often should someone driving an acre of orange sheet metal have to use his horn? "Did you not see that giant orange truck with the camper shell on it"?!
#18 |
#19 | |
Who Changed This?
