Old 05-15-2017, 10:32 AM   #1
68 C10 LSX
Grinding when I turn left and right
Used to post here under "My New 72" more than a few years ago but haven't been on in a while. The truck was in storage for 6 years and I just got it out to and on the road again. When I parked it, everything was good. It rode and drove great. The issue I am having now is, when I turn the wheels either direction to turn, there is a pretty harsh grinding going on. Everything feels tight, but its rubbing somewhere and I can't readily see where it's coming from. Any suggestions on where to start? The front shocks are tired and need replaced, but I wouldn't think that would cause anything like this. Thanks for the help.
68 C10 LSX is offline   Reply With Quote
Old 05-15-2017, 11:11 AM   #2
67 chevelle
67 chevelle's Avatar
Re: Grinding when I turn left and right
bad shocks can defiantly cause front end sag , allowing your tires to contact the inter fenders on sharp turns , replace them and see what happens
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 05-15-2017, 11:14 AM   #3
dfwright
dfwright's Avatar
Does it happen when rolling, or does it also happen when sitting still?
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 05-15-2017, 11:35 AM   #4
68 C10 LSX
Just rolling and it sounds like a metal on metal grind.
Old 05-15-2017, 12:02 PM   #5
fatbass
fatbass's Avatar
If it goes away when you hit the brakes it's wheel bearings.
'71 C/20 350/T350.
fatbass is offline   Reply With Quote
Old 05-15-2017, 12:07 PM   #6
Boog
laying low
Boog's Avatar
You very likely have rusted brake rotors too.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 05-15-2017, 12:09 PM   #7
demian5
demian5's Avatar
How????
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 05-15-2017, 12:24 PM   #8
67 chevelle
is your truck lowered , if not the disregard . Have a buddy look at it while you turn wheel and roll slow
Old 05-15-2017, 01:25 PM   #9
weq92f
If you have a POSI rear end, that could be doing it too. The clutch pack/plates can get very noisy when cornering if your rear fluid is bad. I've only experienced this when the fluid is HOT like after driving down the highway for a while, but I suppose if your truck has been sitting that long, this could be your issue.
Not sure how you would test this. Maybe jack up the rear and hold one wheel while turning the other, see if it's notchy or noisy.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 05-15-2017, 02:37 PM   #10
demian5
demian5's Avatar
Shocks DO NOT carry any load at all, they are along for the ride (even in coil over and strut applications, the shock is a dampener of compression and rebound of the suspension ONLY). On an air shock, the air bag part holds weight, not the shock part.
If it were lowered and the shocks were fully compressed because of improper application, they would hold the ride height higher, not lower.
If it were a stock height truck and the shocks were fully extended because of improper application, they would hold the ride height lower.
In both cases, there would be other issues that would be present as well.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 05-15-2017, 04:55 PM   #11
68 C10 LSX
Truck is lowered 4/6. I thought wheel bearings could be the issue and will jack the truck up and give them a spin and see. I didn't think about the rear-end though. I'll give it a look as well. It's been a while since I have messed with this thing and it seems like I have forgotten so much. Need to spend some time on here just reading and catching up. Thanks!
Old 05-15-2017, 10:50 PM   #12
Steeveedee
Who Changed This?
Steeveedee's Avatar
Noise turning right to left sounds more like you have cavitation in the power steering pump. Check to see if it is full. If not, top it off and turn the steering gently from lock to lock. DO NOT crank the wheel hard when you reach the stops. Also, limit this turning to no more than 5 times, and then move the truck some distance. If you keep turning from lock to lock and don't move the truck, you can wear flat spots on the tires, and get an imbalance. That of course depends on how rough the surface is.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 05-16-2017, 07:44 AM   #13
zach_carver
zach_carver's Avatar
I would check brakes also, make sure a caliper isnt stuck or something possibly.
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 05-16-2017, 12:15 PM   #14
68 C10 LSX
Issue definitely isn't the power steering pump. I know that sound, and this isn't it. I'll give the wheel bearings and rear end a look this weekend.
Old 05-17-2017, 08:55 AM   #15
BugzC10
BugzC10's Avatar
Check to see if your inner wheel rim is making contact with you lower control arm. When I lowered mine I had the same noise when making a hard left or righ turn. This all depends on your wheel size and backspacing.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 05-17-2017, 08:56 AM   #16
JohnJ@RideTech
JohnJ@RideTech's Avatar
X2--Valid Points
John J.
Sales/Tech
Direct Line: 812-481-4737
Office: 812-482-2932
JJohnson@ridetech.com
Instagram: @ridetech_john
JohnJ@RideTech is offline   Reply With Quote
Old 05-17-2017, 03:22 PM   #17
68 C10 LSX
I'm almost positive it's the rear end now. I drove it up the parking garage ramp and got some tire chirp on the hard corners along with the grinding. Not feeling any feedback through the brake pedal either and I would expect to if the bearings were worn and grinding on the spindle etc. Still going to check everything over this weekend.
Old 05-17-2017, 05:17 PM   #18
mattfranklin
mattfranklin's Avatar
Sounds like a good plan. At least change the fluid before you go too far in mechanically.
Another wild thought. Make sure the lug nuts are tight. Could be someone messed with them while in storage.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 05-19-2017, 07:05 AM   #19
4gearchev
My 72 is lowered about the same amount in the front with drop spindles. I have had problems before with the rim hitting the lower control arm on sharp turns, they are 15" rallies from Speedway. Sounds like the same noise you described. Check underneath for fresh metal. Hope that helps
4gearchev is offline   Reply With Quote
Old 05-19-2017, 09:21 AM   #20
68 C10 LSX
Yeah, I used to have that issue until I ground off the curled lip on the ends of the lower control arms to stop it from happening. I'm running 18's now too, so it was only happening at full lock coming out of parking lots and the suspension would get loaded on one side.
Bought the gear oil yesterday but have to order the gasket because no one around here has one in stock.
Old 05-19-2017, 10:14 AM   #21
weq92f
If you gear oil doesn't have the Posi additive already, be sure to add some.
-klb
Old 05-30-2017, 03:20 PM   #22
68 C10 LSX
Changed the gear oil over the weekend and it looked good. A little low, but good. Still have the grinding when turning, no change at all. Didn't have a jack to get the front wheels off the ground, so removing the front wheels and rotors to check the bearings will have to wait until I get back in town in a couple weeks. I was really hoping changing the diff. oil would fix the issue. Oh well, just another reason to get dirty.
Old 05-30-2017, 03:28 PM   #23
TXBoudy
TXBoudy's Avatar
I bet you won't stow it away for years again... They have feelings you know, though yours seems to be of vengeance. Good luck getting it purring again.
Boudy
Boudy
Project "Deplorable"
Door Panel Build
TXBoudy is offline   Reply With Quote
Old 05-30-2017, 03:34 PM   #24
68 C10 LSX
Definitely not going into storage again. Found some rust bubbling through the inside roof around the door seam the other day too. Very unhappy about that. I didn't really need another reason to blast the cab and get rid of the hugger orange paint, but now I have one.
