Old 05-23-2017, 07:38 PM   #1
wake328
$1600 to spend on engine - stroker or better heads??
With all things considered equal as far as machining costs go to freshen up the block (its already .030 over)... here are my 2 scenarios on how I spend $1400 to $1600ish dollars.... thoughts....
1. Keep stock stroke and buy the $1600 AFR heads (I would freshen up my current speed pro flat top pistons with new rings)
2. Buy stroker rotating assembly for $800ish and use box stock vortec heads $640 new (limited to a mild cam)
Where will I see the best HP for the $$$....
wake328 is offline   Reply With Quote
Old 05-23-2017, 07:45 PM   #2
WB72
Before and After
WB72's Avatar
Re: $1600 to spend on engine - stroker or better heads??
IMO, if you stroke it, you will want to get the heads as well. Get the heads now. You won't be disappointed. You may even forget about the stroker.
Too many guys think that cost is too great for heads and put lesser amounts of $$ in other places and regret it. If you can afford it, do the heads. I wish I would have did it in that order. Heads will add a ton of power on their own.
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 05-23-2017, 07:49 PM   #3
demian5
demian5's Avatar
Drop it and put some wheels on it.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 05-23-2017, 08:27 PM   #4
davepl
davepl's Avatar
Where do you want the power?
If you want to launch from a stoplight, you need more torque. A stroker kit will give you that.
If you want more acceleration once you get going up around 5000rpm, you want more horsepower. Good heads will give you that.
Big dollar heads will do little down low, but can make a world of difference in a drag race application or similar where the RPMs come up early and stay there.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-23-2017, 08:41 PM   #5
Mike C
Mike C's Avatar
Torque is what makes driving everyday fun. And heads are a bolt on that can be done in the vehicle at a later date. I'd go for the stroker kit.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-23-2017, 09:56 PM   #6
towbar
towbar's Avatar
Location: Marshall, NC....heart of the Appalachians.....aka, Gods country!!
An engine is a air pump, more air in = more power/torque out....IMO and experience, heads are the lungs of the engine. Doesn't matter what CI the engine is, if it cant get the air in, the power won't come out. More cubes make more torque, but torque and power are still directly related to airflow.
towbar is offline   Reply With Quote
Old 05-23-2017, 10:22 PM   #7
Robznob11
Robznob11's Avatar
If what you have runs well ....sell it and get the blueprint 383 turn key, it has good flowing aluminium heads. My buddy just got one and its pretty salty. I know lots of guys who build with hi dollar parts (ie...afr etc) and end up thinking they have mor hp then they really do. A well thought out and matched combo almost always performs better and is more fun even with less than top notch parts. Now if you are a master mechanic and know how and have the means to balance it and build it then do the heads!
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 05-24-2017, 10:11 AM   #8
wake328
Solid point... definitely more difficult to add a stroker kit later on versus heads. A part of me feels guilty not utilizing the perfectly good crank, pistons and rods that I have... Could always pick up another project for them :-)
Old 05-24-2017, 10:16 AM   #9
JustToxic
JustToxic's Avatar
With the budget you have, I would stay away from doing a stroker. Instead you'd see better results doing a balanced and blue printed build with a good set of heads. Most people think you can just throw parts at a engine and it will run and have a ton of power. If you use your money wisely and do research on what parts work together you can build a engine that run very well and reliable, and you won't have a ton of money into it. The main thing you need to ask yourself is how you plan on using the engine, do you want power out of the hole or do you want to be able to rev it to the moon and have all top end power? Once you figure out that, then you can decide how to build the engine. If you have questions on any engine part your looking to buy don't be afraid of calling the manufacture and asking tech questions, they can be a ton of help.
1967 Chevy C20 to K20 Conversion "Simply Toxic"
http://67-72chevytrucks.com/vboard/s...d.php?t=749409
1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775
JustToxic is offline   Reply With Quote
Old 05-24-2017, 10:24 AM   #10
Robznob11
Robznob11's Avatar
Wink Re: $1600 to spend on engine - stroker or better heads??
What he said!, but to add to that by the time you get it done you could have just bought a crate with a warranty that will do as good or better. Alot of people dont consider the time of build either
LED TAILS
Old 05-24-2017, 10:26 AM   #11
wake328
hands down... my favorite kind of power is the feeling when you dont need to stomp on the pedal and you can just kind of roll it on... making power up top has never been as exciting for me. I love the low end pull
Old 05-24-2017, 10:32 AM   #12
wake328
$1600 isn't my total budget... more or less deciding where a big chunk of the budget will go and I want to make sure I don't mess up that decision!
That big decision is... run the current speed pro flat tops with really nice heads and stock stroke.
Or... stroker the engine with stock vortec heads.
Old 05-24-2017, 11:47 AM   #13
webfoot
Get the AFR heads and then also start getting the stuff to go with a hydraulic roller cam. More power everywhere. On a pump gas 383 chevelle and a voodoo hyd roller with AFRs, I ran a 8 flat in the 1/8 with a full interior and 3.31 gears, drove it to the track about an hour away, made 10 runs and drove it home. The guy I traded it to swapped in the better converter I gave him and it ran in the 7.70s.
Clay Smith cams makes hyd rollers specifically for the AFR heads.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 05-24-2017, 11:59 AM   #14
skytop
skytop's Avatar
Do the stroker. As you should know, the torque will put a smile on your face.
You can then easily do the heads later when time or money permits.
This is the win-win approach.
1972 C10 SWB, 1970 Corvette, 2017 Grand Sport
skytop is offline   Reply With Quote
Old 05-24-2017, 12:07 PM   #15
paulspickupparts
Not sure of your horsepower goals but with a spring/guide upgrade on the vortecs and a different cam (fairly mild) you should be in the 400 horse range. You really did not mention if is a roller cam or flat tappet .
The AFR heads are great but eat up budgets . Also a large runner head on a small engine is not really necessary . Lot of different AFR versions. Good AFR head and matched cam you can add some horsepower over the vortecs .
Kind of depends how you drive . If you like to rev to the moon pickup a moon cam . If you like a torque cam buy a torque cam . Or something in the middle. Torque cam will be fun to drive around town . Radical cam can get kind of old in town .
paulspickupparts is offline   Reply With Quote
Old 05-24-2017, 12:31 PM   #16
Maximus
Maximus's Avatar
lol, a strait 50/50 split on opinions, hope that helps you! heh...
If you WANT a stroker, I would do the bottom end now. You can swap heads and even a cam later without ripping into the bottom end...
If your not set on a 383, reuse your good parts and put a good set of heads on.
Maximus is offline   Reply With Quote
Old 05-24-2017, 12:37 PM   #17
wake328
This is a hydraulic flat tappet block. The modified vortecs at first glance seem like a great deal, but once you get into all the odds and ends of modifiying them.... it hardly seems worth it compared to a set of edelbrock e-street heads for example.
Old 05-24-2017, 01:17 PM   #18
BrianG
BrianG's Avatar
I'd go with Vortec heads and a cam that is suited for the combination of those heads and the pistons/deck height, etc. You can pretty easily make a 350 make 400 ft lbs of torque and well over 350hp. And still have something that has enough vacuum for power brakes.
If a stroker is still in the budget, then, sure go that way. Will your current carb be enough for a stroker though, just another consideration.
BrianG is offline   Reply With Quote
Old 05-24-2017, 01:50 PM   #19
paulspickupparts
They make springs that do not require machining of the heads with different hardware that give enough clearance up to 550 lift . Should be able to have a set of vortecs for about $800 new . I think the eddys are 900-1000 . Good heads also but not as good as edelbrock e-tecs or AFR . Both of the later will blast your budget.
