Old 10-24-2003, 09:56 AM   #1
fatboy63k10
Transfer Case Whine
I have a 63k10 with a t-221 Rockwell t-case. It whines badly. I pulled it, and discovered that the bronze bushing on the front input shaft (from trans) was worn badly to the point that the constant mesh gear had slight "wobble" play and the front output shaft (to front rear) was seized onto the helical constant mesh gear.
I replaced all the bearings, turned a new bronze bearing for the input shaft and replaced the front output shaft from a spare case. I reset and shimmed the whole assy according to the book specs as far as end play, preload etc...
Now the bastard whines worse than ever.
Is this a situation like a ring and pinion where "matched, run in gears" can't be messed with or reset ever again in their lifetime? What are my options for this t-case? I know of no parts available...
fatboy63k10 is offline   Reply With Quote
Old 10-24-2003, 10:17 AM   #2
GreenMystChevy
Well, I can't answer your question all the way or even to the point but I thought that I would share the fact that the Rockwell 221 is a loud one. From what I hear from others who own one, it wines all of the time and loud enough for people to comment on.
Good luck.
Jeremy
'71 C-10
'72 GMC K2500
'72 Nova (Dad's)
'70 Chevelle SS
'55 Sedan Delivery
Attempting to build up this here 4x4...make her real tall and purty...well, maybe just tall
GreenMystChevy is offline   Reply With Quote
Old 10-24-2003, 12:17 PM   #3
ckhd
ckhd's Avatar
All the t-221s I've had whine. Some louder than others.
I don't know enough about them to tell you how to get rid of it.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 10-24-2003, 12:46 PM   #4
fatboy63k10
I guess it's not possible to describe the extent or what might be "acceptable" for a whine or a noise. The service manual itself states at the end of the section that a "certain amount of noise" is common or acceptable. The noise I have starts almost immediately from a rolling start and the pitch gets higher the faster the truck rolls and pretty much drops out at about 60 mph. It comes back on deceleration almost to a stop. Since I haven't been in another equipped truck, I have no experience to feel comfortable. I don't think I'm going to live with it. I'm going to pull it back apart or find something else.
What other divorced t-case would be an easy swap? np205?
btw- here is this pos I've given the last 2 years of my life to.
http://www.picturetrail.com/fatboy63k10
Old 10-24-2003, 03:40 PM   #5
GreenMystChevy
Now that is a beautiful truck! Nice job. It's all in the details and you certainly have that covered.
Jeremy
'71 C-10
'72 GMC K2500
'72 Nova (Dad's)
'70 Chevelle SS
'55 Sedan Delivery
Old 10-24-2003, 04:38 PM   #6
fatboy63k10
Thanks!
It has been suggested to me that once a gear set develops a whine, its there to stay. The noise was there to begin with and adding the foreign helical gear changed the gear lap two-fold. I suppose my next best guess is to cross my fingers, and rebuild the donor case.
Old 10-24-2003, 05:38 PM   #7
1969 GMC
1969 GMC's Avatar
i have the 221 also, and i agree it is very noisy. i havent dropped the case to look inside, but i changed the oil and no shavings or anything bad like that, so i assume its doing good. now that i have my stereo setup, its not as bad. its really loud, esp when accelerating and when compression braking, and the shift lever rattles too. but from everyone i've heard that its normal. 5k miles (and counting) and no problems.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 10-24-2003, 11:09 PM   #8
Scrub
Collector of rusty Items
Scrub's Avatar
My buddy has a 221 with 70k miles on it. I think he would consider a hundred dollar bill. email me at twscannell@hotmail.com if you are interested. It's in Oregon.
Good luck
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 11-16-2003, 12:22 AM   #9
ZOOMY
rockwell whine
If they don't whine, there's probably something wrong them. If you really hate the whine that bad, convert it over to a 205.
ZOOMY is offline   Reply With Quote
Old 11-17-2003, 02:35 PM   #10
Yukon Jack
Post Whore
Yukon Jack's Avatar
That truck is awesome. Everyone needs to take a second and go look at his pics.
Can't help on the whine issue - my 69's T221 has a pretty nice whine also.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 11-25-2003, 11:36 AM   #11
Destructo
My 208 whines in low range but no whine in high range. Sounds like a whine in that case is pretty normal.
Destructo is offline   Reply With Quote
Old 11-25-2003, 08:21 PM   #12
gman
A POS?
You must be kidding.................
Pretty nice, I'd say!
72 Chevy SWB Custom Deluxe K10, 350/SM465, PS, PB, Fact. Air
2000 Harley...Wide Glide
gman is offline   Reply With Quote
