Old 07-12-2017, 09:08 PM   #1
Gene Letke
Replacing window felts
I have a new set of door window felts. Can't seem to find a YouTube video on how to remove the old ones and install the new ones. I'm pretty sure I understand how they are fastened but sure would like to see what I am in for. Anyone have any words of wisdom before I attempt this?
Gene Letke is offline   Reply With Quote
Old 07-12-2017, 09:44 PM   #2
Shinysideup
Shinysideup's Avatar
Re: Replacing window felts
Welcome to the site.
Hit the search button,lots of info available.
._____________
..\ .___ . . . . _ . .\. . . . . . . . . . . ___
..| /_+_/ ___ |o| ...}. . . . . ______i__!\____
. [_____(O)_|_'|__}>-------[-_(O)__i'___i (O)-]
Originally Posted by 68 P.O.S. View Post
No thank you on that lifetime warranty. I don't want a turd for life.
Shinysideup is offline   Reply With Quote
Old 07-12-2017, 09:53 PM   #3
Gene Letke
Yes, thank you. I did find lots of old discussion on that subject. Should have done that first before Posting. New to site, need to learn how to navigate better.
Old 07-12-2017, 09:56 PM   #4
randy500
You can read my door assembly instructions, link in my signature line...I explain the tool to use and how to use it. Best performed with helper to grab onto the felts and keep upward pressure while you release the clips
randy500 is offline   Reply With Quote
Old 07-13-2017, 01:02 AM   #5
El Dorado Jim
http://67-72chevytrucks.com/vboard/s...g+window+felts this is a great thread on doing door work
El Dorado Jim is offline   Reply With Quote
Old 07-24-2017, 10:28 PM   #6
Gene Letke
I removed the old felts without much problem using a pliers. I install the new inside felts and the length was right on. The outside ones were a 1/8" too long on each end. I cut them off with a tin snips. Just like I had read in other threads on this subject, the rubber started not to seal correctly as it got closer to the vent window. This is the area of the largest gap between the inner and outer door skins. Not as bad as others complained about, will just have to live with it.
window felts
