![]() Join Date: Jan 2007
speed warning question
i acquired a complete 67 speed warning cluster with knob, harness and buzzer. wondering what it will take to add the speed warning to my 68 choke delete cluster. what other parts do i need? what's involved? having a hard time finding info/threads on this.
I live in California, but identify as a Texan ![]() "If a job's worth doing, it's worth doing well" Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
Old member
There is very little info on them but several guy's on here rebuild them and sell them. Parts are very hard to find to rebuild them.Do a search and you should find some info.
Clusters already rebuilt are in the $500.00-$600.00 range! ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
How did I get this OLD!
![]() Join Date: Dec 2014
Re: speed warning question
I believe the only thing you will need to do is drill the hole in your choke delete bezel for the needle adjuster and swap the gauges over. I did that with mine.
http://67-72chevytrucks.com/vboard/a...1&d=1500554381
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
thanks guys
Roadtrip!
![]() Join Date: Feb 2003
Just put your bezel on this setup and drill the hole for the adjuster. Ready to go.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Old member
I misunderstood what you wanted. I thought you wanted another parts cluster to build for the 68.
All you need is like said above. Just drill the cable adjuster hole in the 68 bezel. ![]()
