Old 07-23-2017, 11:08 AM   #1
Nutty57
Red face Just getting started looking for floor pans
Where is the best place to purchase replacement floor pans for a 72 C10
Nutty57 is offline   Reply With Quote
Old 07-23-2017, 12:45 PM   #2
AussieinNC
Moderator
AussieinNC's Avatar
Re: Just getting started looking for floor pans
Anything this size will need truck freight...
Try :
https://www.summitracing.com/parts/oer-t70815
$ 480 plus $ 99 truck freight...the box is approx 6 feet x 5 feet x 12 inches and weighs approx 75 pounds...
Put a WTB on the Sales boards on here...you will need a paid subscription...
You may find a closer vendor and be able to pick it up...
AussieinNC is offline   Reply With Quote
Old 07-23-2017, 01:34 PM   #3
Cooper Restorations
Cooper Restorations's Avatar
We are located in Marion Indiana, and stock most anything you need. We are close enough that you could come pick it up and avoid shipping. We carry Tri Plus and Woodall brand sheetmetal. www.cooperrestorations.com or give me a call at 765-661-1723. We would be happy to help you
Cooper Restorations is offline   Reply With Quote
Old 07-23-2017, 01:52 PM   #4
Nutty57
that's awesome close enough to drive and pick up ....thanks
Old 07-23-2017, 02:10 PM   #5
AussieinNC
Moderator
AussieinNC's Avatar
Really glad to see the board working so well...
I always try and support local guys especially for sheet metal supplies etc
Can I suggest you check out your kick panels, cab corners and outer rockers before you take the drive...
Double check your trans tunnel height...most full replacement floors are low tunnel, if you need high tunnel, most re-sellers carry the new high tunnel pieces...
Assume you know to jig the cab up with bracing before you begin...if not, search the board, there are several threads dedicated to cab floor replacements...
Have fun...
Old 07-23-2017, 05:42 PM   #6
Cooper Restorations
We stock the high, and low hump floors both.
Old 07-23-2017, 07:48 PM   #7
Nutty57
Thanks for all the help I've restored several cars but first pickup so any info is helpful.....Thanks again
Old 07-23-2017, 08:34 PM   #8
Cooper Restorations
No problem. We would be glad to help any way we can.
