07-24-2017, 03:12 PM | #1 |
door hinges
hi how are the 67-72 after market door hinge are they any good as in fit and lining up the door
07-24-2017, 03:34 PM | #2 |
Re: door hinges
I need some also or someone who rebuilds them
07-24-2017, 03:43 PM | #3 |
Re: door hinges
Clean up the hinges and replace the bushings and pins and hinges should be good. Better than repop too
Heat up the hinge sleeve and pound pin out with hammer and drift pin Shouldn't take more than an hour or two. Search YouTube. Saw vid there also. Mark
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
07-24-2017, 04:19 PM | #4 |
Re: door hinges
Get on you tube and look up Gibson 63 . He has a good video on doing this on his 63 Chevy.
07-24-2017, 04:29 PM | #5 |
Re: door hinges
i think the left ones on my truck are bent so just will try to find some old ones and redo them
07-24-2017, 06:33 PM | #6 |
Re: door hinges
I got a hinges for both doors from LMC. My 70 GMC is being painted and the body shop had no complaints with the new hinges. Everything was removed from the truck, so they had to rehang and align the doors anyway.
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI |
07-24-2017, 09:11 PM | #7 |
Re: door hinges
The Gibson 63 videos are impressive, I would say he has been around the bock on a few restorations, I stumbled onto his videos a while back doing research on painting. if you have time to kill he is definitely worth a look.
07-24-2017, 09:57 PM | #8 |
Re: door hinges
Bushings - GM # 9721917
Pins - GM # 20046147 Dorman also has a kit, Dorman # 703-264 The pins are too long and will need to be cut to length. |
