Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 07-24-2017, 09:38 PM   #1
GMCNUT
GMCNUT's Avatar
WTB: 1963 factory Power brakes
1963 was a weird year and there were lots of little differences between 63's and the later 64-66's - the earliest run of 63 trucks equipped with factory power brakes had vertical booster brackets as seen in the photos below, and had a thin STEEL spacer behind them mounted to the firewall vs the 64-66 trucks having an Aluminum wedge and horizontal brackets. So, in all your plundering around local salvage yards and looking through old junk trucks around, keep an eye out for any 63's that might have one of these for me. Thanks, Steve
My Projects and Toys - All 100% Stock
1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction
1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar
1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock
1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd
1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet
1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight
1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB
1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet
1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet
1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet.
GMCNUT is offline   Reply With Quote
Old 07-25-2017, 07:35 PM   #2
sigshooter
sigshooter's Avatar
Re: WTB: 1963 factory Power brakes
I don't have the steel adapter plate but I do have a new reman booster for a 63
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
Old 07-26-2017, 10:42 AM   #3
GMCNUT
GMCNUT's Avatar
So the booster you have is off a 63 truck w/ vertical brackets like the ones shown? so how were you going to mount and use it with no steel spacer?
Old 07-26-2017, 05:07 PM   #4
sigshooter
sigshooter's Avatar
I got the booster off here from another member, it was suppose to be for a 64-66. It is the vertical style brackets, I had to order another booster from Oreilly's with the horizontal brackets that fit my 1965. I have had this 1963 style booster for about 3 years now. I need to renew my membership so I can legally offer it up for sale, but that is how I ended up with the new 1963 style and no steel spacer.
if you have a steel spacer a machine shop can make you one (or more) fairly cheap. I have had the aluminum brackets for the 64-66 made and power steering conversion brackets made and all have been affordable.
1966 Short stepside
1964 long bed
Old 07-26-2017, 08:30 PM   #5
bakwoodsfarm
Aren't the boosters and brackets the same, just unbolt from the booster and rotate? I was thinking the adapter plate was the only real difference. But there are a lot of people smarter than me.
Brad
bakwoodsfarm is offline   Reply With Quote
