07-26-2017, 05:27 PM | #1 |
Best gear ratio for lq4 or lq9 w/ 4l65e
What will be the best gear ratio for a 6.0 ls swap with a 4l65e in a 67 c10.
The truck will be use both for city and occasionally highway use. \\\\\\ |
07-26-2017, 05:53 PM | #2 |
Re: Best gear ratio for lq4 or lq9 w/ 4l65e
I'm by no means an expert but it will depend on specific factors on your vehicle. main thing your missing is your tire size. . This calculator might help you.
http://www.angelfire.com/fl/procrastination/rear.html
Lifted 2wd 1969 C20/ 5.3LS/4L60E :http://67-72chevytrucks.com/vboard/s...d.php?t=728388 |
07-26-2017, 06:52 PM | #3 |
Tire height plays a huge role in rpm. I have a 27" tire and 3:42 in my suburban It needs more rpm for performance and towing. Cruise on freeway it's great.
Same goes for my work truck it has 32" tire and 3:73. It needs at least a 4:11 to work the way I wish it would. Even a 4:56 wouldn't be out of the question. Play with the rpm calculator and decide what you want most out of the truck. Hwy cruiser or performance hauler. Remember the Denali trucks came with 4:11 and 32" tire and they are quick.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
07-26-2017, 08:06 PM | #4 |
I won't run anything bigger than a 29" tall tire. I don't see myself hauling anything with this truck. It will be bagged and on a PB Extreme drop member
07-26-2017, 08:17 PM | #5 |
3.73
07-26-2017, 08:40 PM | #6 |
Old member
My LQ4 has the 4 l80e behind it along with 4:10 gears. Highway is 16-18 MPG and the stop light to stop light is fun also.
07-26-2017, 08:59 PM | #7 |
My truck is bagged too
07-26-2017, 09:10 PM | #8 |
72mario,cool setup!
07-26-2017, 09:21 PM | #9 |
07-26-2017, 09:22 PM | #10 |
07-27-2017, 06:29 AM | #11 |
Old member
Because I bought the whole setup out of a 04 heavy duty with 70,000 miles on it.
07-28-2017, 07:48 PM | #12 |
What Jocko said.
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
08-14-2017, 12:36 AM | #13 | |
My '55.2 has same LQ4/4l85e combo but 3.73 final rationand 235/55x17 tires so I wonder how it'll do for mpg and mileage as well?
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
08-14-2017, 06:35 AM | #14 |
Old member
My trucks info is all right here. When I took it to the tunner and put it on the DYNO machine he said the 4L80E takes a lot of HP to operate. My HP # was @290. All stock except for header's.
08-14-2017, 07:08 AM | #15 |
Designated A-hole!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
08-14-2017, 07:41 AM | #16 |
I have 3.73s in both of mine ,one with overdrive 200-4r , and one without turbo 350 , both work great with 29 inch tires
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
08-14-2017, 11:02 AM | #17 |
3.73
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
