07-27-2017, 10:50 AM | #1 |
Shock Recommendations
Looking for shock recommendations for my 2000 GMC RCSB Z71. This is my daily driver and I know it being a 4x4 Z71, as well as it being so short that I can expect a little bit of a rough ride but I'm looking to try and smooth it out some. Not necessarily looking for it to ride like a car but I would like to make it a more comfortable ride. All suspension is original other than a set of keys in the front. Any recommendations you guys can give me would be greatly appreciated. So let's hear your thoughts.
07-28-2017, 03:09 PM | #2 |
motor exploder
Re: Shock Recommendations
Bilsteins. Hands down. I'm running the second set now (got the heavy duty version this tune around) on my '05 GMC 1500 crew cab. Night and day from stock shocks or parts store Monroes, etc. Handle great, ride smooth, and can handle plenty of towing. I'm also running Bilsteins on my '65 Bel Air wagon. Well worth the extra money.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
08-29-2017, 06:57 PM | #3 |
Bilstein 5100's and remove your front sway bar. My HD rides very well with bislteins and no sway bar. It leans a little bit more in turns but rides so much better. If you tow or haul weight often id keep the sway bar on or have it handy to reinstall.
08-30-2017, 08:40 AM | #4 |
If you lower the front or put the factory keys in, it will ride a ton better. It rides like a dump truck with the bars cranked up that high, And all the keys do is allow you to crank it higher than the factor keys will allow.
Also a vote for bilsteins. Best shock in the world. |
09-05-2017, 11:06 AM | #5 |
Where did you all buy your Bilstein's?
09-05-2017, 12:27 PM | #6 |
I went with Bilstein 5100s on my Tahoe and it was a huge difference. I got mine at Rock Auto.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
