![]() Join Date: Aug 2009
Just Quoted $800 For Plugs & Plug Wires
I really like the shop. But I can't throw my money away like that. Does anyone know of high quality plugs and wires for a C10 that are tailor made for a small block with Doug Thorley Tri Y headers?
Re: Just Quoted $800 For Plugs & Plug Wires
summit has good wires , tailor-made not sure
Stan 67 swb BLU MULE posted via flip-fone |
![]() Join Date: Feb 2002
For $800 bucks their other customers must be laundering money!
It's not so difficult to do it yourself. Tri-Y headers are not very common these days, so you need to fit a custom loom anyway. Best wires I've found are Taylor's. Get a universal fit set and cut to length, then crimp on the connector. A good crimper [and wires and plugs] would fit inside that $800 budget. Don't forget the champagne, guys who help you with $800 wires will be non-plussed if you only offer beer. JK. You didn't say if you have HEI or stock points. Most of the universal kits have terminals and boots for both included. You need: *Wire set -- 7mm for points, or 8mm for HEI. [There's also 8.8mm and 9mm available, but I'm not launching a moonprobe, so I don't need that kinda stuff.] *Tube of silicon dielectric grease. Pre lube the booties -- easier to pull thru. *Plugs. What ever you like. This can be an endless debate around here on what's best. Stay away from platinum and multi-tip types, just gimmicks, and you can't clean 'em up with a small file like the copper tips. . . *Crimpers. Ratchetting type are pro grade. [I still use the mini-anvil Accel type -- you put the lower jaw in a vise, and hold the upper in your fingers and tap it secure with a light hammer. Carefull with fingers. If I were new at it, I would just get ratchetting crimpers. Easier to work with.] Jegs has high end MSD crimpers for $84.22. Still inside your $800 budget. P/N121-35051. *Needle nose pliers. *Utility knife -- for stripping back insulation on wire leads. *Dykes -- for getting a clean cut on wires. *Tunes -- Good for morale and pace. *Time -- Yours is not as expensive as Shop Time, which I'm guessing must be $125/hr. Take your own sweet time and be proud of your work. Spend the other 600 or 700 on caviar for breaktime.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 07-27-2017 at 05:22 PM. |
#4 | |
HUGE HELP. Thank you so much. Do they sell the ratcheting crimpers at Home Depot/Lowe's? I was just thinking to myself, "I brought the truck in for a tuneup, and was preparing myself for $400 at the high end, unless they find something else wrong with it." Then, when I got quoted the $800, I thought to myself, "I just installed a front disc conversion. Plugs and wires probably won't be a problem." I like the shop a lot. They've been around for 80+ years, their garage bays are filled with classics, and they do good work. And I know that they need to make a substantial profit in order to pay good wages. I'll take my truck there when I'm in over my head. |
#5 | |
I use a shop for brakes, transmission, engine machine work, glass and differential work, but otherwise I tackle it myself -- usually with help from friends, either volunteers or bribed ringers. These trucks were made and designed to be simple to maintain with common tools. Unlike what is made now. I edited my first post after you replied [but before you saw it] so you might go back and rewiew.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 07-27-2017 at 11:26 PM. |
laying low
![]() Join Date: Mar 2001
That quote basically says they really don't want to work on your truck. They priced it so high only a fool would let them do it.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
![]() Join Date: Jun 2009
I will sell you mine for 600
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
![]() Join Date: Jul 2009
bring it to me in hb work from home
Who Changed This?
![]() Join Date: Jan 2013
Looks like camtoys1 has you covered. Plus, you get to BS with a fellow member while you wait!
I can do a complete points ignition tune up (plugs, points, condenser, cap and rotor, set dwell, timing and mixture if required) in less than an hour on my truck. Add an hour for wires.
~Steven '70 Chevy 3/4T Longhorn CST 402/400/3.56 Custom Camper Simi Valley, CA Last edited by Steeveedee; 07-27-2017 at 09:38 PM. Reason: too many words |
Here ya go, Short, your new drinking buddy, I mean wrenching buddy. Be sure to pop for champagne, unless he insists on beer.
Camtoys -- show the kid where the candy stores and goodie shops are. You got a lot of 'em down there, Brothers, Truck and Car, etc.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 07-27-2017 at 09:37 PM. |
#11 | |
One night I was coming home from work - minding my own business in my '71 Jimmy... When this dude in a green later-model, GMC pickup pulls alongside and says "How much?'' ''Twenty-Five " I said, and pulled ahead to the next light. Now he's all hot and bothered, "2500, I could do that!" He says, when he catches up to me. The light changes again. He pulls alongside again. ''No, 25 Grand," I said. That soured the ''deal''. I mean, really? Did I have a For Sale sign up? Yes I could get 2 or 3 trucks for that kind of money but if you're stupid enough I'll sell you mine for a rediculous amount. Or don't bother me on the road. ![]()
![]() Join Date: Aug 2015
$800 Dooolllllars? For plugs and Wires?
#13 |
At the body shop.
Holy cow, that's the I'd rather not price.
While your there cap and rotor wouldn't hurt
" That didnt make it any newer " " Dont antique the equipment " |
#14 |
All about them K’s
![]() Join Date: Jun 2014
Fwiw napa sells the wire, crimpers, and ends to do the job. They may have to order it all, but you should be able to have everything in a day or two.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
#15 |
![]() Join Date: Jul 2015
800 bucks really????
Here is what it did, buy a set of crimping pliers, 30 bucks. Then get these plug wires from any local auto parts retailer: https://www.summitracing.com/parts/acc-5040y If you can use the straight plug design its a go. This I believe is the longest set of wires they make, just cut accordingly! |
#16 |
Go Pack Go!
I'm sitting here giggling over "$800 for plugs and wires".
#17 |
For that price they should at least take you to dinner first.... K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#18 |
motor exploder
I'm using spark plug wires (LiveWires) on my '69 C10 (big block w/headers) and my '65 Bel Air (small block & ram horns) from www.performancedistributors.com. They are of very nice quality and are offered in many different lengths and boot styles to accommodate different headers/manifolds. I'm also using one of their DUI distributors on my bel air. Highly recommend.
You can do cap, rotor, plugs and wires and use the other $600 for other important stuff like beer.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
#19 |
I know they're 9.5mm but for the price...https://www.amazon.com/Degree-Spark-...g%2Bwires&th=1 I put a set on a SBC boat last year and they are still doing just fine, seemed like a fine wire set up.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
#20 |
![]() Join Date: Nov 2004
Huh. $725 in labor for a 30 minute job?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#21 | |
Who Changed This?
#22 |
![]() ![]() Join Date: Sep 2008
I have made plenty of wires, but I don't understand why the tailored plug wires for C10 wouldn't work just as well with tri-Y's as with the stock manifolds as long as they are routed in the factory location.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
#23 |
And a reach around!
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
#24 |
![]() Join Date: Mar 2013
You said you like that shop, and I respect your opinion. Even if they did price it that high just because they didn't want the work, it kind of ruins my trust. It would make me question how bad they had hosed me in the past, as well as the future if I was to ever go back. Jmho
Justin '67 C20 CST Custom Camper '04.5 LLY Duramax CCSB...sold |
#25 |
![]() Join Date: Dec 2013
Again ! OH MY GOD ! $800.00 ? I would have smacked the guy to bring him back to reality ! But you are in Orange county CA so you should expect to pay 5 times the actual cost ...
