Old 07-27-2017, 06:30 PM   #1
cadams85
Question
I have a 1985 c10 has 273 gears was going to put 373 gears in it where is a good place to purchase some thanks
cadams85 is offline   Reply With Quote
Old 07-27-2017, 08:42 PM   #2
SilverMachine
Re: Question
I recently just did this swap a few weeks ago in my 86. These days pretty much whatever price you see on jegs or summit racing will pretty much be the standard anywhere, unless you have a pop shop around who's willing to help out. i got the All-star gears and the Auburn positraction differential...gears were around 170 i believe and the diff was around 400 or so. dont forget the gear installation kit which will run around 100 bucks.
SilverMachine is offline   Reply With Quote
Old 07-27-2017, 08:51 PM   #3
cadams85
Re: Question
I appreciate the input I put a 355 flat top pistons in with 10 to 1 compression can't remember the cam size but have double hump heads I bought a tcI street fighter 700r them 273 suck got 20 on my truck so geared even higher
Old 07-27-2017, 09:00 PM   #4
SilverMachine
Re: Question
yeah haha same! they guy who put my gears in saw the tire size and said it was more like 2.50 something that 2.73! im doing some engine work next week and got a streetfighter converter too i think. just be prepared for your speedometer to be off....i believe im running around 55 when my speedometer says 75....so it will probably be similar with yours unless you have aftermarket gauges which i dont know how that will effect it.
Old 07-29-2017, 07:46 PM   #5
Jay2Cor517
Jay2Cor517's Avatar
Re: Question
I did this swap last year to my '86 GMC (peg-leg 2.73). After doing research, I decided on a Detroit Trutrac by EATON. But going this route meant I couldn't use the OEM axles which in the end is a good thing--they are now 30 spline Moser's. I also upgraded the diff cover to one that came with adjustable load bolts. I bought all the pieces from Summit. But you should be able find any and all the pieces from any vendor on the web. The only hiccup came when my installer didn't like one of the bearings that came in the Motive Gear installation kit. He thought it was a touch too big. He ordered a smaller size that he preferred (don't know which one or brand). Here are some links to different sites you may find handy for this project. I also included my parts list. Hope this helps, Have fun
EATON TruTrac YouTube video https://www.youtube.com/watch?v=lZmsY2YvVsc
EATON Catalog http://www.eaton.com/ecm/groups/publ.../ct_128302.pdf
Gear Ratio Calculating, SuperChevy tech article "The Numbers Game" http://www.superchevy.com/how-to/148...o-calculating/
Tire Size Comparison https://tiresize.com/comparison/
Parts List (all Summit Racing Part Numbers):
Detroit Trutrac DTL913A481
Moser Axles MSR-A3079GMTK
Motive Gear Ring and Pinion Sets MGR-GM10-373
Motive Gear Master Ring and Pinion Installation Kits MGR-R10REMKT
Timken Wheel Bearing TMK-6408
Timken Axle Seals TMK-8835S
Summit Differential Support Cover SME-8510300NL
Everything that can be counted does not necessarily counts; everything that counts cannot necessarily be counted--Albert Einstein
Jay2Cor517 is offline   Reply With Quote
Old 07-29-2017, 08:17 PM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Question
I found a decent price at las vegas drivetrain parts when I was looking for parts for a mopar price was good haven't received them yet to talk quality
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 07-30-2017, 05:55 PM   #7
abig84
abig84's Avatar
Re: Question
i went the cheap and easy route and just bought a rusty pos k5 blazer with no title for $400 and just swapped over the axles.
going from 273 to 373 is a big improvement
abig84 is offline   Reply With Quote
Old 07-30-2017, 10:46 PM   #8
cadams85
Re: Question
Yeah that sounds like the way to go I've looked around for used rear end no luck
Old 08-01-2017, 10:41 PM   #9
cadams85
Re: Question
I talked to one of my friends and he said truck is usually 30 spline he also said I would have to buy a differential probably go with positive trac he said I just couldn't put 373 gears and pinion in it anyone else no anything about this
Old 08-02-2017, 07:30 AM   #10
Rich84
Rich84's Avatar
Re: Question
The C10's were 28 spline until 1988 they went to 30 spline.
Rich84 is offline   Reply With Quote
Old 08-02-2017, 08:51 AM   #11
cadams85
Re: Question
Thanks for letting me know before I buy the 30 spline then they wouldn't have worked so thanks
gears, question
