07-29-2017, 08:58 PM | #1 |
**Big Block Engine Mounts**
Changing the small block in my 69 flatbed over to a 454. Have a set of 72 frame stands but not the clams. I know there is a difference in the clam shell height. Anybody have clam shells they want to sell (or the set). OR, if I could get a measurement from the face where they bolt to the block to the center of the hole, maybe I can make some later ones work.
07-30-2017, 05:39 PM | #2 |
Re: **Big Block Engine Mounts**
Bump to top...........any help out there?....bueller?
07-31-2017, 08:04 AM | #3 |
2WD Jimmy
You might check with Wes at Classic Heartbeat Pickup Parts in Washington State.
07-31-2017, 09:09 AM | #4 |
I have never checked the height but have seen claims here on the forum that newer ones are the same as big block, hopefully someone has your answer. I have a big block truck on the lift I could try getting a picture with a ruler next to it
07-31-2017, 09:30 AM | #5 |
Measured as in picture, the clamshell is from a square body small block, measurement is about 2.1
I cant get a pic of the big block but it measures about 2.3 |
07-31-2017, 01:39 PM | #6 |
I've got a couple different sets here and they measure from 2-3/8'' up to 2-3/4. Pictures I've seen here give me the impression that the 72s fit pretty tight like the 2.1 you mentioned. I'd like to find out and I'm sure the info would be nice to have on the website
07-31-2017, 01:51 PM | #7 |
I think yours at 2.4 are correct because that's what's in my 72 big block truck.
07-31-2017, 01:54 PM | #8 |
I will try to get a picture, the bottom where the one in the pic mounts pokes out towards the block between the holes, the one on my big block doesn't look like it does that
07-31-2017, 01:57 PM | #9 |
Some pics here but not of a lot of use...
http://67-72chevytrucks.com/vboard/s...d.php?t=310749 |
07-31-2017, 02:00 PM | #10 |
Here is another thread
http://67-72chevytrucks.com/vboard/s...ht=clam+shells Mine in the 72 big block truck do have the part number on the drivers side, can't see the pass because it's greasy. Part number shown in his thread http://67-72chevytrucks.com/vboard/s...d.php?t=649056 |
07-31-2017, 04:29 PM | #11 |
07-31-2017, 05:36 PM | #12 |
So.....looking through all the information and what I have here, I'm wondering if the stamping on the mount itself has any significance. For instance, one of the links shows the 72s and there is a stamping on the surface that bolts to the block.........looks like a smiley face. Some of the clams I have, have a triangle both stamped and raised. Another set has the smiley face but it is stamped the opposite direction from the picture showing the 72s.
07-31-2017, 05:49 PM | #13 |
Do you have any with that part number where the last 2 digits are very large "22" I can see that stamped on one the drivers side
07-31-2017, 05:50 PM | #14 |
I would bet classic bow ties has some....I think his name is Mel, in Portland oregon
07-31-2017, 06:16 PM | #15 |
08-01-2017, 05:12 PM | #16 |
Here ya go. The holes were wallowed out a little but maybe this will help.
08-01-2017, 05:13 PM | #17 |
2222
08-01-2017, 05:13 PM | #18 |
3333
08-01-2017, 05:14 PM | #19 |
4444
08-01-2017, 05:15 PM | #20 |
5555
08-01-2017, 05:17 PM | #21 |
Last
08-01-2017, 06:02 PM | #22 |
Those pics are great, can you try to get a measurement from the upper block mount holes to the edge of the same hole?
Maybe trace a straight line on the table, line up the upper holes on that line and them use a square to find the edge of of the through bolt hole |
08-01-2017, 07:41 PM | #23 |
Thanks for the Pictures and measurements. Looking at that I could use what I have sitting here by those measurements. I don't think it's going to push the fan too far up into the shroud and the manifolds should clear the stands
