Door Switches Necessary?
My instructions from the Painless Wiring Kit state that the interior lights are switched through the optional door switches and/or the dash-mounted headlight switch. It states that these switches supply ground to the circuit.
In goes on to say that if you are using door switches, you will need to add wires connecting them. I never noticed before but our truck doesn't have the door switches. Should I drill holes and install the switches or will the ground for the headlight switch be all I need? Thanks, POP
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Door Switches Necessary?
It's up to you. With door switches, the interior light comes on when you open either door. If your truck doesn't have door switches and you've never missed having the light come on, why bother adding switches now? If you decide to add them, it isn't hard to do -- with the possible exception of fishing the wires through.
#3 | |
I also like that no body knows that these lights are manual. Miranda Lambert - "Back before everything became automatic" Bill
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
