08-02-2017, 12:11 PM | #1 |
Anyone else doing Ram Air?
Ram air set up I made from a gas can. Not sure how I feel about it? Thoughts? Does it look out of place?
08-02-2017, 12:17 PM | #2 |
Re: Anyone else doing Ram Air?
I like it.
Grandpa 1953 M38A1 Jeep 1989 GMC K2500 1958 Alaskan Camper all original WORK : A necessary evil that finances what I really like to do. |
08-02-2017, 12:17 PM | #3 |
Big Block
Should bring in cool air. Looks good to me.
08-02-2017, 12:25 PM | #4 |
Looks good. What's the intake tube made out of?
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
08-02-2017, 12:34 PM | #5 |
thats pretty darned cool!
08-02-2017, 12:45 PM | #6 |
Old member
Cool sir! I like the fab work and the use of the gas can for the base.
More of a cold air though than ram air. Which are both better for the engine.
08-02-2017, 12:47 PM | #7 |
Tube is Commercial 4" Flex duct, I used exhaust wrap to hide it.
08-02-2017, 01:03 PM | #8 |
There is some ram effect there in front of the radiator support (which is why the radiator works, too).
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
08-02-2017, 01:34 PM | #9 |
Very nice.
08-02-2017, 02:02 PM | #10 |
Holy Crap! Look at that upper radiator hose!
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
08-02-2017, 02:30 PM | #11 |
Old member
Not sure what you mean by this but the cold air coming in is way more effective than the ram part is.
08-02-2017, 02:43 PM | #12 |
A "cold air" intake is typically an intake that's just been relocated to a cooler area under the engine bay. They usually pull in "dead air" that's surrounding them, but it's cooler air because it's farther away from the engine.
A ram air is forced air from the outside and because he went through the core support and is taking air from the front of the truck, I'd say calling it a Ram Air is fine and makes sense. The early firebirds (and even the late models) had Ram Air hoods that took air form the very front of the car. The air flow would be significantly different if he just put one of those snorkle intakes behind the radiator support. I like it, good job.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
08-02-2017, 02:45 PM | #13 |
At the body shop.
2010 ish silverado hose I believe
" That didnt make it any newer " " Dont antique the equipment " |
08-02-2017, 02:48 PM | #14 |
Yeah, I didn't notice it at first, looks like a carbed (or Fitech? style EFI) on a 5.3. I thought it was a plain old 350 at first glance.
08-02-2017, 03:06 PM | #15 |
looks awesome , should work just as good as it looks
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
08-02-2017, 04:27 PM | #16 |
Old member
The cooling of the air is more important than the ram air effect if any on a carb or EFI system guy's.
A throttle-body-mounted air filter may look trick, but it ingests preheated under hood air from the radiator and the engine compartment. The best-running EFI cars breathe cold air from a front mounted inlet outside the motor compartment. The ram air effect doesn't even happen unless the vehicle is moving. How much depends on how fast your going. The whole thing is about cooler air though and that is what he has coming in, so he is good. Lot better than the guy's who just stick a tube over behind the head light with a filter under the hood anyway! Blocking off the filter under the hood from the rest of the area helps but it's nothing compared to true cold air.
08-02-2017, 04:39 PM | #17 | ||
What I am saying is that there is a high pressure area at the front of the truck (or the base of the windshield) that helps the air along the flow path. That's what would be considered ram air. I would agree with this summary: Quote:
a) I designed the air induction system for the GMT800 version trucks, portions of which are still in use today. b) The car pictured below is the '65 GTO that Pontiac engineering developed the '65/66/67 "ram air" package on. That car, and the prototype air pan, are sitting in my back garage, as they belonged to my father. In that application the car draws boundary air off the surface of the hood, so there is not much ram effect, but the resulting cool air was worth a .2 sec reduction in ET in the quarter mile. As a result, I do have some fairly strong opinions (and objective data) on aftermarket "cold air" systems and engine air induction systems in general. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 08-02-2017 at 04:56 PM. |
08-02-2017, 04:45 PM | #18 |
That's a very cool idea. I like it.
68 c10 swb stepper 68 c10 swb stepper 67 c10 lwb 06 gmc duramax |
08-02-2017, 04:46 PM | #19 |
Looks good. I am working on one also.
http://67-72chevytrucks.com/vboard/s...d.php?t=698292 |
08-02-2017, 05:05 PM | #20 |
The "high pressure" area you refer to in front of the radiator... it's enough to move air through the radiator's huge surface area, but it's not going to supercharge your cylinders or anything.
In other words, you're going to pick up some power from the colder air, let's say 5hp. And you're going to pick up some 'boost' from the ram air effect, let's say 0.00001hp Of course I don't REALLY know what the numbers are, but the "ram air" effect is pretty minimal. It's not zero, but close. Nice fabrication btw!
08-02-2017, 05:35 PM | #21 | ||
In the example above, it takes about 407 HP at the flywheel for this factory lightweight tripower GTO to run a baseline of 12.42 in the quarter mile, in NHRA B/Stock trim. Adding the ram air pan and completely removing the hood scoop nose piece (hood ornament) and hood bracing behind the opening decreases the ET to its B/Modified Production best of 12.18, which requires about 420 HP to achieve. That's a 13 HP increase, primarily from the introduction of cooler air (not much ram effect). That might not sound like much, compared to your estimate of 5 HP (although it's more than double) but if you know any racers you'd know that they would kill their own mother if it would result in a two tenths reduction in ET. I'm familiar with what we in engineering call "directionally correct but not measureable" changes, but this is not one of them. I have asked my GM Powertrain contact if he has any current rule-of-thumb guidelines that they use for HP vs air temp or HP vs ram. I've forgotten what we used on the GMT800 program, as that was 20 years ago. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 08-02-2017 at 05:42 PM. |
08-02-2017, 05:46 PM | #22 |
I believe the power increase for temp is 1% for every 10 degrees, or that's what I read. Let's say you drop the air from 140F ro 90F, that's 5%. On a 300hp motor, that's 15hp.
But my point was whether it's 5 or 15, it's a lot more than the ram air effect, that's all I meant.
08-02-2017, 06:01 PM | #23 |
I like William's idea and I plan to build something like it. Keith, what would you recommend for intake plumbing? I'm running a mildly built Vortec 5.7 with a Quadrajet, and your opinion is greatly appreciated.
08-02-2017, 07:07 PM | #24 |
Very nice fabrication work, I like it a lot!!
1971 Longbed BB Cheyenne Super 1972 Longbed SB Cheyenne Super 1972 Longbed Highlander Custom Deluxe 1975 K5 4x4 full convertible Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165 Greg Smyrna TN |
08-02-2017, 08:10 PM | #25 | |
Old member
I wished my dad had been able to keep some of his company cars when he was with GM. 7 kids though made that tough I guess. Here is my cold air setup in my 71 C10 with 2004 6.0 installed. 4" hole in support 94 caddie air box modified to take 4" ninty. I sealed the factory opening up Finished product. Yea I need to get the bend out of it but as of yet I haven't found anything that works.
