Old 08-06-2017, 11:35 AM   #1
suburban99
suburban99's Avatar
Knock sensor problems
72k10 with an LQ4 swap
Getting PO327 and PO332
Downloaded the troubleshooting guide
And checked the following:
Sensors to ground ohms out to spec (99.9 and 100.7)
Wiring from sensors to PCM checks out
AC voltage test is good right to connector on PCM
Next step is replacing the PCM
Anything I missed?
1962 C10 Longbox LS 5.3 4L60E----Sold$$
2014 Ram 4x4 3500 Laramie Diesel..Momma's truck
2015 Ram 4x4 1500
1997 Boxster.
1972 K10 Custom Deluxe LS 6.0
1950 GMC 3100 S10 & LS swapped
suburban99 is offline   Reply With Quote
Old 08-06-2017, 02:15 PM   #2
Hidesertchevy
Re: Knock sensor problems
Replace both sensors and harness
Hidesertchevy is offline   Reply With Quote
Old 08-06-2017, 02:26 PM   #3
suburban99
suburban99's Avatar
Sensors And harness are new..
2015 Ram 4x4 1500
1997 Boxster.
Old 08-06-2017, 02:32 PM   #4
Hidesertchevy
Then could be pcm problem
Old 08-06-2017, 08:14 PM   #5
sprint_9
sprint_9's Avatar
Have you had it tuned, or is everything stock in the engine and tune?
sprint_9 is offline   Reply With Quote
Old 08-07-2017, 12:55 AM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
How many times has it triggered? Like if you clear the codes, do you get any period of function before the light pops up?
If you can watch live data, look at what the KR* count actually is, and see where the histograms show the hits counting. If you have a physical interference (things like transfer case, exhaust, trans xmember) touching/vibrating against the motor, it can actually trigger a large single hit of knock. It would show up on the logs as a spike, instead of a plateau like an actual knock condition would.
Even easier....can you hear an actual knock? Because your getting BOTH sensors to trigger the same conditional code, it means there is either; a problem with the hardware (loose pigtail, partially shorted wire that only contacts under certain conditions), a kr threshold set oddly (unlikely unless tuner got ambitious, or sloppy), or an actual knock severe enough and frequent enough to trigger both sensors at the same time under the same circumstance.
The only time replacing the PCM is a logical step is when there is an actual internal board failure, driver failure, component mismatch..or pissing off my tuner. If you think the PCM could be a cause, then try hard grounding the case. Probably best to check your grounding straps on the head and block as well, or consider adding some if you've streamlined the factory layout.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-07-2017, 03:13 AM   #7
suburban99
suburban99's Avatar
I can drive the truck for about 4-5 Miles (sometimes further) with some hard acceleration then the check engine light comes on. The PCM is not original to the truck, I bought it from a member here. I do have the original but would need to be programmed.
I can't hear a knock or detonation but exhaust is loud..and I am slightly deaf..
I have added additional alligator clip grounds to PCM case and block..
Because the truck is a 4x4 and runs 35's it can be a rough ride over some bumps...I did disconnect the PCM this morning when I checked wiring so maybe the connection wasn't good? I read somewhere that plug gap could cause the KS to trigger? Just got truck on road so we will see this week.
2015 Ram 4x4 1500
1997 Boxster.
Old 08-07-2017, 05:45 PM   #8
elf w/capital T
don't go cheap with sensors and senders. I have learned multiple times already with my ls swap, temp, oil, crank and knock sensors. don't get the cheap stuff, you will have to replace shortly after!!
elf w/capital T is offline   Reply With Quote
Old 08-08-2017, 12:21 AM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
^ very true when it comes to knock, cam, and crank sensors especially.
If you baby the truck, can you go farther? Does it seem like there is a certain situation in which it will always happen? Again, live data from a scanner or HPT would tell you if its "real" knock or not.
Whats the story on the motor? If there was a ton of blowby, or something like assembly lube from break-in, its possible even new sensors can get fouled out.
Old 08-08-2017, 10:13 AM   #10
ls1nova71
ls1nova71's Avatar
You posted this just after midnight, so I think you're getting sleep deprived! Pretty sure its not possible to foul out a knock sensor.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 08-08-2017, 10:36 AM   #11
truckdude239
truckdude239's Avatar
i repalced the knocks in my 02 suburban didnt make it 200 miles kight back on i pulled the pos advance bwd sensors out and used ac delo and a dorman harness light never came back
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 08-08-2017, 11:16 AM   #12
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Midnight, after a friends 3 day wedding weekend. I havent slept in about 50 hours. Time for bed.
Old 08-12-2017, 12:26 AM   #13
suburban99
suburban99's Avatar
Ok still having knock sensor issues..
I moved my OBD port into the cab so I can watch live data while driving.
The one thing that I noticed is the vehicle speed says 0mph...
I installed a Dakota Digital SEN-01-4L60 AND A SGI-5E speed sensor to cure a missfire I had (haven't had a misfire since)..should the speed data that the DD is giving the PCM show up on my Bosch 1100 reader? Or do I have an issue with the vehicle speed setup.
2015 Ram 4x4 1500
1997 Boxster.
Old 08-16-2017, 07:26 PM   #14
v30crewcab
v30crewcab's Avatar
are the knock sensors torqued to spec?
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 08-16-2017, 07:33 PM   #15
suburban99
suburban99's Avatar
No they are not...I am going to re-torque to 15ft pounds this weekend. I know they are much tighter than that.
2015 Ram 4x4 1500
1997 Boxster.
Old 08-17-2017, 11:10 AM   #16
ls1nova71
ls1nova71's Avatar
The torque spec is so you don't over tighten them. They can be damaged by doing so. If they are damaged then re-torquing them wont help.
Old 08-17-2017, 11:41 AM   #17
suburban99
suburban99's Avatar
I'll replace them with GM sensors...live and learn
2015 Ram 4x4 1500
1997 Boxster.
Old 08-18-2017, 12:54 AM   #18
suburban99
suburban99's Avatar
Changed out the sensors for GM sensors...my Son's an apprentice Tech and gets parts at dealer cost..unfortunately he works for a VW dealership...they were $90.00 each (CDN) holy crap. Well hopefully it's the fix. Torqued to 15ft Lbs..we'll see tomorrow.
2015 Ram 4x4 1500
1997 Boxster.
Old 08-18-2017, 07:27 AM   #19
72MARIO
72MARIO's Avatar
I feel the parts cost hurt. I actually was just going to tell you to check amazon.ca
I got delphi knock sensors for $57.73 each and free shipping.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 08-18-2017, 04:01 PM   #20
suburban99
suburban99's Avatar
I saw those but wanted to get it fixed as I am travelling next week. I only live 9 miles from the border and have a US PO box too...most if not all my parts come from the US. Good news is the problem is gone! Drove 80-90 miles today and no check engine light...Thanks to all for your help!
2015 Ram 4x4 1500
1997 Boxster.
