08-08-2017, 08:52 AM | #1 |
Sputtering under heavy load
Truck details: SBC 350/th350, edelbrock carb, big solid roller cam.
Drove it Friday night, it was fine. Drove it 100 miles saturday, it was fine. Saturday evening I pulled the valve cover to change the gaskets to thick rubber gaskets only to realize I need long bolts to run them, so put the older rubber gaskets back on. Then I changed my oil yesterday (Valvoline 10w30 and Lucas oil treatment). Took it out last night for a drive, and under WOT it's sputtering from about 3k-4k rpm. Driving it under normal conditions (even and slow on throttle), it runs fine all the way to 5k. Sputters once it gets up in RPM from a stop as well. I spilled some oil when filling it back up, so was thinking maybe the #8 plug/wire got wet. Pulled the wire and the plug and seemed fine. Put it back on and drove it to work this AM, and it's doing the same thing. Coincidence that this didn't start until the oil was changed? Runs great until the pedal is mashed, idles great, etc. So after searching I see this could be a number of different problems. Edit: Seems to be a common problem with the 1406 edelbrock carbs. Am I off base here? I'm thinking either ignition issue, or fuel delivery issue? Last edited by zachste; 08-08-2017 at 12:04 PM. |
08-08-2017, 12:49 PM | #2 |
Re: Sputtering under heavy load
Almost sounds like it doesn't get enough fuel for some reason. Partially plugged fuel filter?
'64 C10 LWB, 283, 5speed '68 C20 LWB, 327, 4speed '69 C20 Custom Camper Longhorn, 350, 4speed '72 C20 Cheyenne Super, 396, TH400 '66 C60, 292, 4speed |
08-08-2017, 01:08 PM | #3 |
Is it a sputter or is it bogging? I had some issues with my 1406 until I adjusted the accelerator pump. Before then, if I accelerated really slowly, it wouldn't bog too much, but if I stepped on it, it would bog down really badly. WOT would cause it to fall flat on its face.
I'm assuming your fully warmed up when you notice the sputtering. If not you'll sputter and bog, too. I'd do what ElKotze suggested and check the fuel filter. Sounds like you might be starving the carb. If all that looks good, I might check the carb floats to see if one is full of gas. My truck sputtered and eventually quit running altogether because the carb flooded.
1969 Custom C10 |
08-08-2017, 01:45 PM | #4 |
if it ran fine before you pulled the valve covers, it may be a plug wire not plugged all the way on the cap or plug,( if you removed them to pull covers) or maybe the plug wire it's self. also check to see if all vac. hoses are on that may have been disturbed while under hood...
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
08-08-2017, 03:01 PM | #5 | |||
08-08-2017, 06:27 PM | #6 |
Sounds like lack of fuel to me. Filter or carb adjustment.
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
08-14-2017, 04:41 PM | #7 |
Just wanted to give an update for future/search references. I checked some normal stuff like fuel filter, debris in a bowl of carb, vacuum leaks, plug wires, plugs, etc all were good. I needed some assistance so took it out to my buddy's shop and first thing he wanted to check was timing. Said no way that could be it. Initial timing was too advanced, brought it back a little lean to I think it was 28*-30* advanced total timing, and ran great after that.
