Old 08-08-2017, 07:00 PM   #1
gmc1971harwich
gmc1971harwich's Avatar
Front 4x4 Id help 72 jimmy
My front diff in my 72 jimmy needs new bearings for pass and drivers side. Def not stock. Has 8 lug and disc brakes the pic below are the numbers I found how do I find a rebuild kit for it with pinion bearing?
gmc1971harwich is offline   Reply With Quote
Old 08-08-2017, 07:16 PM   #2
72k5ls
Re: Front 4x4 Id help 72 jimmy
You have a dana 60 front axle now pull the cover and look on the ring gear for some stamped numbers to see what year model it is.
72k5ls is offline   Reply With Quote
Old 08-08-2017, 09:17 PM   #3
gmc1971harwich
Thanks will pull the cover off when I can get another gasket and check the numbers
