08-11-2017, 01:24 PM | #1 |
10 Bolt Rear End
I haven't been able to find any info on my rear end. Anyone have and links to charts to help? Thank you!
08-11-2017, 03:01 PM | #2 |
Re: 10 Bolt Rear End
Well it's not a 10 bolt. It's an Eaton but not sure which model. Try google 1964 Eaton axle. There are I believe 2 models...
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
08-11-2017, 05:29 PM | #3 |
I counted the bolts around the back and assumed it was a 10 bolt since it had 10 bolts. hahaha! That's what I get for thinking it was that simple. Thanks for the help. I'll check it out.
08-11-2017, 06:07 PM | #4 |
1965 Chevy C10, 2005 4.8L/4l60
Probably an Eaton HO33 if 1/2 ton, not the most desirable and parts can be scarce and spendy
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
08-11-2017, 07:09 PM | #5 |
08-11-2017, 09:39 PM | #6 |
HO-52 then.
http://6066gmcclub.com/archive/index.php/t-47314.html If you can, swap out to a FF 14bolt from a GM or Dodge truck. Got disc brakes and ready parts availability. Good luck!
08-12-2017, 12:20 AM | #7 | |
08-17-2017, 10:44 AM | #8 |
Knowing nothing about your potential build, or you...have you thought about converting it to a 1/2 ton? That might be easier....parts would be common..
