Old 08-12-2017, 12:37 AM   #1
dmartin1
dmartin1's Avatar
Z FRAME LINING. Need help
I welded bracing before and after the cut to keep frame rigid.
After the cut, i am trying to line up to weld and box it in.
How do you guys do this? See my pics, i have 1 side clamped matched up abd even/flush. The other side sticks out about an inch. It looks like its due to the taper in the frame.
Do i weld 1 side flush like it is with the clanps, then use the clamps to pull the other side in?
There was no tension when i cut, and no springing out of the frame that i could see.
Could i have braced a fea inches too far away?
Any help here would be great before i continue
Thank you
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 08-12-2017, 12:39 AM   #2
dmartin1
dmartin1's Avatar
Re: Z FRAME LINING. Need help
Pics
65 nova
And more
Old 08-12-2017, 09:46 AM   #3
rockyrivermark
So your cutting down to a short bed right?
If so you should cut out the 12" under the cab area where the frame is straight.
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 08-12-2017, 10:08 AM   #4
saxart
saxart's Avatar
What he's doing is called "Z'ing" the frame. It's done as an inexpensive way to "lay frame" without having to replace the front suspension cross-member. I've never attempted anything like this, but from what I'm reading, it works, but does bring about some other issues that arise after making such a drastic change.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
Old 08-12-2017, 10:28 AM   #5
rockyrivermark
Ah. Interesting. Never heard of that before.
Cool.
Old 08-12-2017, 05:09 PM   #6
dmartin1
dmartin1's Avatar
False alarm, i figured it out.
I must have braced tpo far back from the cut and the frame has some spring in it or somethibg.
What a PITA to get that squeezed together, and at the right height etc.
Next time ill put 50 braces lol.
65 nova
And more
Old 08-17-2017, 07:27 PM   #7
WB72
Before and After
WB72's Avatar
You can keep the braces very close to the cut, just enough for the grinder, or plasma. I had the same problem when I shortened my frame.
If your cuts are at angles, you are going to gain wheelbase length, which will center up the wheel in the front wheel well, but if it is too much your steering column will need to be modified.
How much drop are you gaining by this? am planning this as well, I was thinking 1.5" because I heard there can be complications over 2". i like to play it safe.
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
