Old 08-15-2017, 12:09 PM   #1
68 Greenie
Where to place to correct heat sending unit?
Okay I'm going to go get the right sending unit (hopefully). Im running the old style 202 heads which doesn't have the place between the 1 and 3 plug so should I place it in the port on the intake or in the top of the water pump? Im running and Edelbrock air gap. I only have a 3/8 in intake and the water pump has a 1/2.
68 Greenie is offline   Reply With Quote
Old 08-15-2017, 12:41 PM   #2
clay68c10
clay68c10's Avatar
Re: Where to place to correct heat sending unit?
Go with the intake crossover and re-thread the intake hole to the right size.
Someone on here was offering a turned-down version of the stock sender if you are reluctant to re-thread the intake hole.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 08-15-2017, 01:18 PM   #3
FirstOwner69
FirstOwner69's Avatar
brian mac is the man to contact. He did mine so I could use it in Vortec heads.
FirstOwner69 is offline   Reply With Quote
Old 08-15-2017, 02:23 PM   #4
briank
He just did a turned down one for me too.....now my gauge works correctly.
briank is offline   Reply With Quote
Old 08-17-2017, 07:33 PM   #5
silverstreak
I agree with putting it in the intake as well. It will give you a more accurate reading of engine temp compared to putting it in the pump.
Just an fyi on something that happened to me years ago so you can avoid it. Measure the sensor probe length to make sure it doesn't bottom out and touch anything. In my straight six, the probe was actually making contact with the cylinder head and causing an way higher temp to read on the gauge as it was measuring the temp of the cast iron vs the circulating coolant. I used a brass bushing to give it some clearance and she shows 180* all day long now.
silverstreak is offline   Reply With Quote
