08-15-2017, 09:39 PM | #1 |
Rochester model B tuning
Anyone have any literature on how to tune a rochester B carb? From what I've found is to set the idle screw to 600 to 700 rpm, adjust mixture screw to highest vacuum, then turn it back in until there is a 20 to 30 rpm drop, then turn it back out 1/4 of a turn. Is this correct?
08-16-2017, 02:54 AM | #2 |
Hollister Road Co.
Re: Rochester model B tuning
Idle should be between 450 and 500. at 6-700 your almost off the idle circuit into the transition circuit. I run the idle screw in till it stops. back out 1-1/2 turns and set to the highest vacuum idle at 450- to 500 at the correct timing
